NUMERICAL INSTABILITY OVER THE SWIRLING VANES
Old   February 8, 2005, 13:34
Default NUMERICAL INSTABILITY OVER THE SWIRLING VANES
Dan
Hi!
Has anyone observed the numerical instability over the swirling vanes. What we have is the flow over a set of vanes. We have pressure inlets and one pressure outlet. What we are observing is the mass flow rate through the pressure outlet is oscillating in a sinusoidal fashion.
Has anyone come across this kind of situation and has any comments/suggestions. We have tried with lowering the under relaxation factors. Even to a small number like 0.001, the mass flow rate is still sinusoidal.
Old   February 8, 2005, 15:48
Default Re: NUMERICAL INSTABILITY OVER THE SWIRLING VANES
Jim_Park
Are you doing a transient or steady state calculation. By that I mean, are you solving
dq/dt = RHS
or
RHS = 0?
Asked another way: are you sure that your problem doesn't actually have a periodic (shedding) solution?
Old   February 9, 2005, 08:12
Dan
I am using RHS=0
It is solved in steady state
TVD scheme Numerical Instability Tempa Main CFD Forum 0 June 29, 2011 01:54
Numerical Instability PattiMichelle Phoenics 2 December 26, 2005 19:49
NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VANES D FLUENT 3 February 9, 2005 15:35
Instability of convection Zeng Main CFD Forum 0 May 26, 2000 05:39
Problems of numerical instability because of high gradients Xiangyang Ye Main CFD Forum 4 September 28, 1998 03:48
