Time-Accurate Simulation
Old   February 22, 2005, 09:36
Default Time-Accurate Simulation
John
I am looking for a good explanation of "Time-Accurate Simulation", what is it and how can it be applied? If anybody knows it, or knows where I can find it, please let me know. Thanks.
Old   February 22, 2005, 13:17
Default Re: Time-Accurate Simulation
Runge_Kutta
Time accurate means the time step is chosen to correspond to the fastest physically relevant time scales. This means you are tracking the solution closely as it evolves in time. It makes consummate sense when there are dynamic things going on in the flowfield.
Old   February 23, 2005, 02:54
Rami
In many CFD simulations, only steady-state solution is sought. In such cases, a common approach is to use a pseudo-time approach, in which the solution is iterated by advancing it in time as in transient flow, BUT the time-step in each cell is different and based on the local stability criteria in each cell. This allows a faster convergence to steady state but the physical meaning of this "time" is lost, i.e., at any intermediate iteration, the solution is NOT a valid transient solution of the problem - it is merely another iterative approximation to the final steady solution.
On the other hand, when the same time step is used throught the grid (in which case it is the minimal local time step in all cells) then the physical significance of time is retained. This latter approach is commonly termed "time-accurate".
Old   February 24, 2005, 09:50
John
Thanks to both of you. Was very helpful. Do you know any reference for more info on this issue? Please let me know if there is any. Thanks!
Old   February 24, 2005, 10:03
Rami
Look for papers on Jameson et al from the early 80's. One of these is
A. Jameson, W. Schmidt and E. Turkel, Numerical Solutions of the Euler Equations by a Finite Volume Method using Runge-Kutta Time-Stepping Schemes, AIAA paper 81-1259, 1981.
The above must have also been published in a journal (probably one of AIAA) at about the same year.
Old   February 24, 2005, 22:51
amol palekar
Time accurate simulation also implies that convergence is achieved at each time step and not only at final time step. amol
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Transient Simulation: Initial Time blackbody CFX 0 April 18, 2010 08:19
Time accurate? Steve Main CFD Forum 2 March 25, 2008 08:39
influence of time step in insationary simulation Sascha Behrens FLUENT 0 December 1, 2005 09:08
