Floating point error
Old   March 10, 2005, 21:39
Default Floating point error
huong
I have a problem in converge the solution. It run for about 170 time steps and then indicate "Floating point error, invalid number". I have tried with different input and it still happen. Can any of you have any ideas where should be gone wrong?
Thank you so much
Old   March 11, 2005, 03:40
Default Re: Floating point error
ulysses
What's the problem you are simulating ? which code ? have you got the source code ? Have you examined all the fields after the error ?
Old   March 11, 2005, 07:32
cfd dude
One possibility is your solution has become unstable. You could try smaller time steps.
Old   March 15, 2005, 00:25
Default Re: RE: Floating point error-to ulysses
huong
I am simulate the 2D tank with inlet and outlet. There is an baffle close to inlet. With constant inlet velocity. Moreover, I want to patch a top part of tank is air. What code do you mean about??
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
