velocity injection
Old   March 21, 2005, 07:35
Default velocity injection
caty
Can you please help me with the calculation of the injection velocity particles?
I know about the nozzle:
The orifice diameter 3mm
Operating pressure: 13 bar
Flow rate: 6lpm
Spary pattern: hollow cone
Spray angle: outer 90, inner 70
Sauter mean diameter: 121 micron
I approximate the velocity using the bernoulli's formula just by taking into account the pressure and the density of the water. Is this correct?
Thank you very much
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
