TRANSONIC FLOW?
Old   March 18, 2005, 06:47
Default TRANSONIC FLOW?
manish mehta
Dear All,
I have been generating mach .85 at the inlet of my suersonic nozzle, but I was wondering if this would cause problems in generating supersonic flow downstream. I was worried about transonic effects. Does anyone know how to calculate the critical mach number for a supersonic nozzle (is there such a thing)...i know you can calculate it for a specific NACA airfoil.
I hope someone can help me, this is extremely important for our experimental design. Hope to hear from someone soon.
-manish
Old   March 24, 2005, 14:03
Default Re: TRANSONIC FLOW?
Jason
Seems to me you can use the area-Mach number relation, unless there's something I'm missing.
(A/A*)^2 = (1/M^2)*((2/(g+1))*(1+(g-1)*(M^2)/2))^((g+1)/(g-1))
Where A is your area, A* is the throat area, M is mach number of course, and g is gamma. Be careful, this is an isentropic calculation. You will back out a subsonic and supersonic number. The subsonic number is your "critical" mach number... at that mach number you will get Mach 1.0 in the throat... any Mach number above that will result in normal shocks, no longer isentropic flow...
John Anderson's book "Modern Compressible Flow" is a good resource.
Hope this helps, Jason
Inviscid Transonic flow of Naca 0012 pankos Main CFD Forum 4 February 13, 2011 04:59
Unbale to get stable transonic flow Alex Siemens 0 February 11, 2009 06:03
Unable to Capture Shock in Transonic Flow Tim Siemens 6 January 29, 2009 06:05
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 13:49
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
