turbulence model for ribbed channel heat transfer |
May 31, 2011, 09:47 |
Kan Rui
Rep Power: 14 |
hello everyone,
Recently I've been working on ribbed channel flow,and heat transfer is of great importance in this problem. I found that heat transfer coefficient distribution calculated by the k-e model (with enhanced wall treatment) are not quite satisfying compared to the experimental results. I wonder if there's some logic to guide me to choose a proper turbulence model, or I can only try them one by one? Your remark are highly appreciated! |
June 1, 2011, 01:40 |
#2 | |
Raashid Baig
Rep Power: 16 |
Ribbed channel flow is a very new area to me can you give more details like the Reynolds number involved, details of operating conditions geometry etc. ? Raashid |
June 1, 2011, 21:34 |
Kan Rui
Rep Power: 14 |
It's a serpentine channel used for internal cooling of gas turbine blade. Reynolds number depend on the hydraulic diameter is around 50,000, rib height is approximately 0.1 Dh, rib pitch is 10 Dh. The channel is square with an aspect ratio from 1/4~4 and it may have a 90-degree or 180-degree turning section. Rotational effects is not considered yet.
June 2, 2011, 00:16 |
#4 | |
Raashid Baig
Rep Power: 16 |
Raashid |
June 2, 2011, 09:53 |
Kan Rui
Rep Power: 14 |
Mach number is near 0.03 so I think it's a incompressible problem. Y+ at most part of the wall is around 3, except for some point on top of the rib ,where yplus can be 10.
June 3, 2011, 01:02 |
Raashid Baig
Rep Power: 16 |
I think since it's an internal flow than you can increase your mesh count (I hope you have sufficient hardware resources) so that nowhere the Y+ is more than 2. Once you have new finer mesh you can "solve to wall" instead of going for wall functions.
June 3, 2011, 06:36 |
allan thomson
Rep Power: 17 |
hi
you probably need to go to a low re turbulence model with Y+ around 1, k-w-sst is a good model. Experience would suggest that the metal temperature is probably being predicted too high. I found this when I did cht analysis on turbine blades. Changing to a low Re model will reduce the metal temperature by around 10 K. Only problem is you'll need a lot of cells 20 -25 prism layers in the boundary layer allan Last edited by azt; June 3, 2011 at 06:38. Reason: left someting out |
June 3, 2011, 06:39 |
#8 | |
Raashid Baig
Rep Power: 16 |
heat transfer w/o turbulence | Andrev | OpenFOAM | 2 | May 12, 2011 13:20 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
how to model heat transfer for the coupled wall | jing113cn | FLUENT | 0 | June 22, 2009 03:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
conjugate heat transfer in circular channel | src | FLUENT | 1 | August 6, 2004 07:13 |
