Field gradient
Old   March 26, 2005, 15:32
Default Field gradient
Mahesh
I am plotting the field gradient of the electric field intensity in a non-axissyemtric geometry.
The gradient reverses direction and seems to be purely due to the algorithm which moves in the increrasing x direction. The algorithm is an upwind scheme.
Please suggest as to what I can do so as to eliminate the effect of the calculation of gradient w.r.t the x direction (which means that the algorithm should actually take the modulus of the gradient so that its value is not based on the co-ordinate system but is only based on its sorrounding values)
Thanks MK
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
from a vecor field to get a gradient of scalar dusky.he Main CFD Forum 4 March 30, 2007 09:08
Dynamic Gradient Adaption: Mulitple Field Variable Steve FLUENT 0 July 12, 2005 17:36
