fastran's singualr axis
Old   March 30, 2005, 05:36
Default fastran's singualr axis
autofly
HOw to set the axis boundary conditions at the fastran cfd software. in the given B.C. TYPE. there is not the axis B.C on the general B.C. menu. BuT in the demo validation examples of the attached PDF files, the grid around HYPERSONIC missile include the axis, so it must be able to deal with the axis b.c. I try to define the aixs b.c as symmetry b.c .it run well .but i can't certain it. who can give me some explatation and suggest. thanks in advance
Old   March 31, 2005, 03:35
Default Re: fastran's singualr axis
Charles
You can also use an extrapolated outlet boundary condition on a degenerated edge (advice from CFDRC). If the axis is a true line of symmetry then symmetry bc is obviously the way to go,but mostly it isn't. So then extrapolated outlet bc works fine. The pre-processor defaults to a wall bc, which is obviously not correct.
Old   March 31, 2005, 21:23
autofly
THANKS I CHECK the result in tecplot, as you said, the symmetry B.C at a axis (half body grid) is not correct. the pressure distribution is not regular. so i try to define it as you suggest. ok, i will try .thanks
[DesignModeler] axis display disparity of model and triad ram881973 ANSYS Meshing & Geometry 14 November 18, 2020 01:21
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
Axis of rotation Dunga CFX 4 May 11, 2003 10:44
AXIS BOUNDARY-CONDITION in Dispersed Phase Flow Remesh K Main CFD Forum 3 November 16, 1999 22:44
