June 30, 2011, 14:54 |
CGNS vs Tecplot Data Format
L.Bryce Whitson Jr.
I need to write a software tool to import a CFD results file, generate path-lines of data throughout the data set, and then export the data to a new set of data files. This is so the data can be used in the RADCAL, narrow-band radiation model.
I am currently doing my CFD calculations using FLUENT which can output to many different formats, but I am considering the use of either CGNS or Tecplot ASCII. I feel like with either data set I am going to have a lot to learn about reading the data into my own FORTRAN program for post processing, but I thought that someone here might have a suggestion on which to use. The final data format I need will look something like this: Path_Length, Temperature, <Species Mole Fractions> The path length is calculated as the straight-line distance from one point to the other. In general we do this on a single plane. I know that I will end up having to interpolate data to each of the sample point locations that I want to use. Any advice is greatly appreciated. |
July 1, 2011, 03:25 |
TWB
Rep Power: 19 |
I'm also interested to know the advantages and disadvantages of these 2 formats. But I think it should be a comparison between CGNS and Tecplot binary, instead of ASCII. I wonder if there is some real advantages if I'm only using tecplot for visualization |
July 1, 2011, 03:52 |
#3 | |
Raashid Baig
http://www.paraview.org/ and http://www.vtk.org/ Much of what you intend to do might be available through Paraview and VTK. |
July 1, 2011, 13:50 |
Scott Rumage
We do a good job of documenting our data format here: http://download.tecplot.com/360/current/dataformat.pdf
One can also use our TecIO library to create a binary Tecplot format here: http://download.tecplot.com/tecio/2009/ One can also use a separate application called "Preplot" to turn a Tecplot ASCII file to Tecplot binary (found on the TecIO page as well). I am not qualified to comment on whether the Tecplot or the CGNS format is better suited for the application. Scott |
cgns, fluent, radcal, tecplot |
Best format for simulation data? | cbisw | Main CFD Forum | 9 | May 30, 2011 02:38 |
tecplot data format | ztdep | Tecplot | 3 | October 10, 2008 01:49 |
TECPLOT file data format Plz Explain | whats_in_a_name | FLUENT | 1 | February 21, 2007 08:50 |
tecplot data format | Harry | Tecplot | 0 | June 24, 2006 17:32 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
