how to print the results from CFX-4.2
Old   June 15, 1999, 20:37
Default how to print the results from CFX-4.2
cfd_99
Who knows how to print the results from CFX-4.2. Thanks
Old   June 17, 1999, 06:56
Default Re: how to print the results from CFX-4.2
james date
Hi, look at the bottom of this command file >>OUTPUT OPTIONS
>>PRINT OPTIONS >>WHAT pick what you want when you want it. Read Chapter 9. in the user guide (~page 159 in 1995 guide) that should tell you all you need to know. Good luck with CFX - you'll need it !! Regards James Date
>>CFX4
>>OPTIONS
THREE DIMENSIONS
BODY FITTED GRID
CARTESIAN COORDINATES
TURBULENT FLOW
ISOTHERMAL FLOW
INCOMPRESSIBLE FLOW
STEADY STATE
>>MODEL DATA
>>DIFFERENCING SCHEME
U VELOCITY 'UPWIND'
V VELOCITY 'UPWIND'
K 'UPWIND'
EPSILON 'UPWIND'
>>TITLE
PROBLEM TITLE 'BOUNDARY CONDITION STUDY'
>>PHYSICAL PROPERTIES
>>STANDARD FLUID
FLUID 'WATER'
STANDARD FLUID REFERENCE TEMPERATURE 2.7300E+02
>>TURBULENCE PARAMETERS
>>TURBULENCE MODEL
TURBULENCE MODEL 'K-EPSILON'
>>SOLVER DATA
>>PROGRAM CONTROL
MAXIMUM NUMBER OF ITERATIONS 1000
MAXIMUM CPU TIME 14400
OUTPUT MONITOR POSITION 5.000000E-01 5.000000E-01 5.000000E-01
MASS SOURCE TOLERANCE 1.0000E-06
>>EQUATION SOLVERS
U VELOCITY 'AMG'
V VELOCITY 'AMG'
PRESSURE 'AMG'
K 'AMG'
EPSILON 'AMG'
>>PRESSURE CORRECTION
PISO
>>UNDER RELAXATION FACTORS
U VELOCITY 7.5000E-01
V VELOCITY 7.5000E-01
PRESSURE 1.0000E+00
VISCOSITY 1.0000E+00
K 7.5000E-01
EPSILON 7.5000E-01
>>CREATE GRID
>>INPUT GRID
READ GRID FILE
FORMATTED
>>MODEL BOUNDARY CONDITIONS
>>PRESSURE BOUNDARIES
PATCH NAME 'FACE-NUMBER-0'
PRESSURE 0.0000E+00
>>PRESSURE BOUNDARIES
PATCH NAME 'FACE-NUMBER-36'
PRESSURE 0.0000E+00
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-3'
U VELOCITY 1.0000E+00
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-8'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-13'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-18'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-23'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-28'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-33'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>SET VARIABLES
PATCH NAME 'FACE-NUMBER-37'
PRESSURE 0.0000E+00
K 1.0000E-03
EPSILON 1.0000E-03
>>WALL BOUNDARY CONDITIONS
PATCH NAME 'FACE-NUMBER-6'
PATCH NAME 'FACE-NUMBER-11'
PATCH NAME 'FACE-NUMBER-16'
PATCH NAME 'FACE-NUMBER-21'
PATCH NAME 'FACE-NUMBER-26'
PATCH NAME 'FACE-NUMBER-31'
>>OUTPUT OPTIONS
>>PRINT OPTIONS
>>WHAT
U VELOCITY
V VELOCITY
W VELOCITY
PRESSURE
DENSITY
VISCOSITY
K
EPSILON
WALL PRINTING
>>WHERE
K PLANES 1
ALL BLOCKS
>>WHEN
INITIAL GUESS
FINAL SOLUTION
EACH TIME STEP
EACH ITERATION
>>STOP
Old   June 20, 1999, 08:54
David Creech
CFX produces a dump file with the results which can be viewed using graphical tools such as View and Visualize. If you want to extract results from the solution and output them to a text file, you can use the USRPRT subroutine.
This subroutine allows you to print out any variable at any time in the solution and at any place in the domain. I have used this to extract data along specific lines in the domain and use the data as the input for other simulations. It is the only way to automate post-processing.
I have posted a sample fortran file using this subroutine at:
http://bgtibm1.me.uiuc.edu/people/d-...lot/index.html
Please read the explanation of this subroutine; I just got it to the point where it did what I needed, and there are a few problems with it. It could be a VERY useful utility with some more work.
David Creech CFD Literature Catalog CFD Subroutine Archive
Old   June 20, 1999, 09:44
John C. Chien
(1). I am surprised that one is still interested in printing out the results file. Back in early 70's, I used to get one big box of printout for every 3-D Navier-Stokes run. Since then, I have decided to save nature resources by using graphic post-processing. (2). For a 3-D case with a 250,000 mesh points, there will be 10 essential variables per mesh point ( x,y,z,u,v,w,p,t,rho,mu ). This is a minimum list, the total number of variables is 250,000 x 10 = 2,500,000. If we print 10 numbers per line, we have 250,000 lines of output. If one can print 80 lines per page using small font size, then we will have 250,000/80 = 3125 pages. This is equivalent to 4 thick books, each with 800 pages. (3). It is a good idea to do internal processing and save only needed results first, without printing or even file saving at all. ( I am constantly running out of disk space. And the solution is vey simple, just delete the files. ) (4). How long would it take to read 4 thick books of computed results? ( I had plotted 3-D results from printout to get velocity vector field plots with arrow heads included, once a long time ago. )
Old   June 20, 1999, 23:32
David Creech
I have never found a need to print out the entire solution. What I have found very useful is the ability to print out single lines or planes of data. I do this in cases where I am interested in comparing line plots of some variable for large parametric studies. This is much faster than starting up a postprocessor, defining a line, and outputing the results to a file.
Another reason that I do this is when I am taking the output of a cfd solution (such as the heat flux at a wall) and use this as the input of another simulation (such as a custom code to predict steel shell solidification).
Old   June 21, 1999, 09:23
John C. Chien
(1). Yes, I think the interface between codes is the place where interaction is always required. (2). And the graphic post-processing or inline-processing is essential to the future of CFD.
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 18:11
Vectorial animation of results in CFX attilio CFX 2 February 24, 2009 18:46
time averaged results as initial conditions in CFX mike CFX 8 May 7, 2007 14:54
Import results to CFX post MatjazR CFX 1 October 17, 2005 09:07
CFX 4.2 Zoltan Turzo Main CFD Forum 4 March 11, 1999 17:31
