August 1, 2011, 02:28 |
#21 | |
sheth roh
Rep Power: 14 |
Do one need a licence copy of the ansys cfx to publish the paper of analysis? |
August 1, 2011, 03:43 |
#22 |
Andrew Coughtrie
Rep Power: 14 |
You always need either a Research License or a Commercial license if you're going to be doing anything that will be published. An academic teaching license should only be used for learning the software.
August 3, 2011, 11:38 |
#23 |
sheth roh
Rep Power: 14 |
Ok. So I have done one experiment but it has about 25% error than the data i have to validate.
I have attached pic of mesh and analysis. I have question that how do I refine mesh? As you can see in image there is no vortex seen behind the truck so I think I need to do refinement near that region. Last edited by sheth; February 24, 2012 at 11:14. |
August 3, 2011, 11:45 |
#24 |
Andrew Coughtrie
Rep Power: 14 |
Can you post a pic of your mesh as well? Also what setting are you using in CFX, what turbulence model, boundary conditions etc?
August 3, 2011, 11:53 |
#25 |
sheth roh
Rep Power: 14 |
Boundary conditions
At Inlet: Velo x dir = 23.55 m/s Velo y & z dir = 0 m/s Turbulance: Intensity and length scale ; fractional int 0.05 m & eddy length scale 0.1 m Temp : Static temp. (288 K) At outlet: Static pr. = Relative pr. : 0 pa At the walls of domain (Including ground): Free slip wall At the surface of truck & support: No slip wall First two image show the meshing over the enclosure. Second shows meshing over truck body (Enclosure suppressed) Last edited by sheth; February 24, 2012 at 11:14. |
August 3, 2011, 12:08 |
#26 |
Andrew Coughtrie
Rep Power: 14 |
I sugest you try to produce a structured mesh with more refinement behind the truck where the features you're interested in are. you'll also need to do a mesh independence study. You should look up wake turbulence modelling and find out which turbulence models are most popular, you'll probably need to do a comparison between a few and your validation data.
August 3, 2011, 12:31 |
#27 | |
Martin Hegedus
Rep Power: 19 |
Or do you mean there is no unsteady vortex shedding? |
August 3, 2011, 12:36 |
#28 | |
sheth roh
Rep Power: 14 |
Here is how I do analysis. 1. In ansys workbench select CFX in analysis system table.. 2. Import my truck design. & Made enclosure around it. 3. Did auto meshing.. (I think this is where I have to do something to make results accurate) So in ansys meshing how do I create a proper structured grid? All I do is just do auto meshing. 4. Then i give input values. I want to know which turbulence model did u chose? 5. Post processing. I wanted to mean that flow doesnt curl around the rear bottom part. |
August 3, 2011, 13:42 |
#29 | |
Martin Hegedus
Rep Power: 19 |
Or, are you expecting unsteady vortex shedding? Of course in real life that is what you will get. But, a turbulence model might not give you that. For example, in general, an ogive-cylinder body will give you a steady base flow using SA or SST turbulence model. |
August 4, 2011, 10:15 |
#30 |
sheth roh
Rep Power: 14 |
Can anyone please tell me how do I do structured meshing?
How do you do a fluent CFD analysis for a boat? | UHMStudent | FLUENT | 2 | July 24, 2011 12:45 |
CFD software capable of modal analysis? | Jim-gineer | Main CFD Forum | 4 | January 14, 2010 09:29 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 10:51 |
ASME CFD Symposium, Atlanta, 22-26 July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 1, 2000 10:07 |
CFD Analysis on Shock/Boundary Layer Interacton'-HELP | Mujahid S. Suhaeb | Main CFD Forum | 8 | December 1, 1999 17:14 |
