Problem Solver
Old   August 4, 1998, 19:07
Default Problem Solver
Rizk, Lisa
If I have a .022" diameter cylinder that is 3' long laying horizontally with water flowing through it at a rate of 80mm/min, What is the pressure in the tube?
Old   August 5, 1998, 12:54
Default Re: Problem Solver
John C. Chien
Draw a straight line between the inlet pressure and the exit pressure will give you roughly the pressure distribution along the tube from the inlet to the exit. Assuming that the flow in the tube is fully-developed flow, the pressure gradient along the tube should be a constant ( you need that pressure gradient to overcome the frictional force on the tube wall. The longer the length of the tube, the larger the pressure difference between the inlet and the exit.
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 14:16
Compilation problem after modifying a solver. PetSul OpenFOAM Running, Solving & CFD 2 October 1, 2009 17:28
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 01:26
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
Solver for a ventilation problem vizag OpenFOAM Running, Solving & CFD 4 February 6, 2009 11:34
