Flow through circular curved stationary pipe
Old   May 13, 2005, 06:07
Default Flow through circular curved stationary pipe
R.Sripriya
I am studying flow through stationary circular(round) pipe.The fluid enters the pipe with a constant velocity. Upon entry, the two surfaces of the pipe experience a pressure difference, the inner surface that of p and the outer surface P+dp. Due to this pressure gradient and the tendency of the liquid to flow from a region of high pressure to low pressure the fluid flows from the outer rim to the inner rim. At steady state one can observe that closer to the inner rim we have liquid of high velocity and at the outer rim low velocity. How is this kind of flow sustained throughout the pipe. a velocity contour plot does not show any back mixing or secondary flows anywhere. can anyone explain this phenomenon
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
Flow laminar and stationary of water in a pipe manuel OpenFOAM Running, Solving & CFD 6 March 24, 2007 18:23
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
Tangential Air Flow in a circular pipe Scott Turner Main CFD Forum 3 January 31, 2005 14:59
