relaxation factors and time accuracy
Old   May 17, 2005, 14:57
Default relaxation factors and time accuracy
Mike
I am wanting to create a time accurate model of an unsteady process. Every time step, the solution is changed by deltaV. If I understand relaxation factors correctly,
Vn+1 = Vn + (RF)*deltaV
where RF is the relaxation factor. Do all my relaxation factors need to be 1 for the solution to be time accurate?
Thanks,
Mike
Old   May 17, 2005, 15:21
Default Re: relaxation factors and time accuracy
Jim_Park
This doesn't seen right.
If you're doing an explicit technique,
V(n+1) = V(n) + dt*(partial V/partial t)(n), (1) where t is the time and dt is the time step,
dt = t(n+1) - t(n). (2)
The partial derivative of V wrt t (eqn 1) is evaluated by finite differences, finite volumes, or some such based on the values at t(n). That is explicit, no iteration, no relaxation.
If you use an implicit technique, the partial derivative of V wrt t is evaluated at some time between t(n) and t(n+1). Then the right hand side (rht) of eq. 1 depends on the solution V(n+1):
V(n+1) = V(n) + dt*(partial V/partial t)(n+?), (3)
Eq. 3 may be solved iteratively, perhaps by relaxation. In that case, the accuracy of the solution shouldn't be effected by the relaxation factor chosen [IF the process converges], but the speed of solution is greatly impacted by the value chosen. Often, the process will not converge to a solution if the relaxation factor is too large!
You might thoroughly sort out first the concepts of explicit and implicit methods, then look into solution techniques for the implicit methods.
Old   May 17, 2005, 16:08
Mani
Here's what Jim said in short form:
If your index 'n' denotes a real-time level, then you're doing explicit time marching, and your relaxation factor must be 1 (i.e. no relaxation).
If the index 'n' denotes one of many iterations within one real-time step in an implicit method, then you can (and should) apply relaxation.
It really sounds like you might be confusing both methods right now.
Old   May 17, 2005, 17:53
Mike
Thanks guys,
I'm using Fluent, with an implicit solver. The help files tell me nothing about time accuracy. I'm currently using underrelaxation, and 30 iterations per time step. The iterations per time step make me think that
Will this work?
Thanks for you time,
Mike
Old   May 18, 2005, 08:44
Jim_Park
Thanks Mani,
Very nice clarification of what I tried to say!
Jim
Old   May 18, 2005, 12:30
Mani
So you are using Fluent. I would like to assume that their code is doing the right thing, so I don't see whyrelaxation of the implicit scheme doesn't work. You should check if 30 iterations are enough for convergence within each time step. Underrelaxation may increase stability at the expense of convergence, so don't use it excessively, and increase the number of iterations.
What was the reason for applying underrelaxation? Stability problems?
Old   May 18, 2005, 14:03
Mike
I used underrelaxtion to stop the residuals from blowing up. I also tried reducing the time step, but it needed to be excessively small to work without underrelaxation. I have enough iterations per time step that my code does converge every time step.
Thanks for the help,
Mike
Old   May 21, 2005, 12:41
Larry Clark
I have just an experience answer for the time accurate question. I have a finte volume implicit Patankar type code(compressible) and have done turbo engine stall inlet inlet unstart problems with it to good effect. I found that if I under relaxed the pressure the result would be to introduce a time lag in the pressure pulse. If I kept the relaxation of the pressure at 1.0 phase would match experiment(I also did studies with shock reflection problems to develop the approach). The relaxation of velocity and temperature did not seem to affect the result. I have no theory for this, just observation.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Purpose of relaxation factors Mohsin FLUENT 5 April 30, 2010 11:57
Relaxation factors Vidya Raja FLUENT 7 September 26, 2006 20:00
Time accuracy Mike FLUENT 0 May 17, 2005 14:56
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
