Computational Aero-Acoustic
Old   December 15, 2010, 02:29
Default Computational Aero-Acoustic
famarcfd is on a distinguished road
Hi all,
at my work i have to perform acoustic analisys on the impeller of a new axial flow fan: i would use a computational aero-acoustic (CAA) approach to realize my study and so, i'd like get some information about CAA.
How can i implement this type of approach?
Are CAA analysis as reliable as CFD predictions?
Can someone answer me?
Thanks in advance!
famarcfd is offline   Reply With Quote
Old   February 8, 2011, 04:42
Bertrand Delvaux
Bertrand is on a distinguished road
Hi famarcfd,
I'm working on the same kind of problem, right now, so unfortunately I cannot bring you some answers but only try to help each other. Of what I learned, it is necessary to split up your problem in 2 parts : the aerodynamics part, with your noise source, being solved by a CFD code, and then a wave propagation code to simulate its radiation from the near field to the far field. I hope this helps.
What kind of CAA code do you intend to use?
Regards,
Bertrand
Bertrand is offline   Reply With Quote
Old   August 23, 2011, 07:14
Peng
penghust is on a distinguished road
hi Bertrand,
if i want to write a code based on the FW-H equation to predicte the far-field noise, what should i do?
any information will be great appreciated.
Peng
penghust is offline   Reply With Quote
Old   August 24, 2011, 15:04
cfdnewbie
cfdnewbie is on a distinguished road
Originally Posted by famarcfd View Post
Hi all,
Thanks in advance!
CAA includes a number of methods, from solving some equations for the acoustic field on a background flow up to a full DNS, where the acoustics come about naturally as a part of the NS solution....
so what level of abstraction/modeling are you talking about??
Wiki might indeed give you a good overview of what is out there:
http://en.wikipedia.org/wiki/Computa..._Aeroacoustics
Cheers!
cfdnewbie is offline   Reply With Quote
Aero Acoustic - Postprocess-FWH Model- Octave Band Manoj Kumar FLUENT 2 December 24, 2013 21:00
[ICEM] A mesh generation for aero acoustic computation ringtail ANSYS Meshing & Geometry 8 June 8, 2010 19:49
Good fundamentals book of CFD & computational aero zaidun CFX 0 April 13, 2006 22:53
Acoustic pressure larry Main CFD Forum 8 July 19, 2002 03:40
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
