Local Lax-Friedrich Scheme
Old   August 27, 2011, 06:58
Default Local Lax-Friedrich Scheme
aaaaaaaaaaaaaa
panou is on a distinguished road
At finite volume discretization we can use for inviscid fluxes at element interfaces the local lax-friedrich scheme (LLF) which has a artificial viscosity.
My question is:
At the faces which are boundaries of domain we use again the LLF flux(using the values of interion element and ghost element) or we use another scheme or simply central flux?
Thanks.
panou is offline   Reply With Quote
Old   August 27, 2011, 07:30
cfdnewbie
cfdnewbie is on a distinguished road
My question is:
Thanks.
You use the LLF as well, and apply the bc through the ghost cell value!
cfdnewbie is offline   Reply With Quote
Old   August 27, 2011, 09:39
aaaaaaaaaaaaaa
ok. Thanks.
No i want to do a question for LDG scheme for flux viscous discretization if you know.
For applying the ldg scheme we must set at each face of mesh, a Right and Left element. Both neighbour elements which have the same face must use the same flux so that to be conservative scheme. In 1D case this is simply to define the R & L element. At 2d how can i determine the R & L of each edge? Can i do this randomly or i must keep a specific orientation ? A manner which i do this is with set a vector for all mesh and thus define the R & L of an edge by sign of vector dot normal vector.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
