Which Package for Mesh
Old   March 22, 2001, 03:14
Default Which Package for Mesh
Selina Tracy
I missed the discussion at this forum in response to John's inquiry of "Mesh generation Package for turbomachinery"
Different packages have been recommended; Gridpro, icem, catalpa or gridgen. What a mess! Anybody who has ever used at least two among these packages and can tell which one is the best.
Selina
Old   March 22, 2001, 03:24
Default Re: Which Package for Mesh
John C. Chien
(1). The code used by the best expert is always the best. (2). The difficulty is to find the best expert. (3). So, everybody is creating the code and looking for the best expert.
Old   March 22, 2001, 03:37
Selina Tracy
Thanks John, Right. We need expert! But what if the code dose not have a feature that is desperately needed.
May I ask if you have ever used any of them. As a most active and wise member of this forum, you do, I guess.
Selina
Old   March 22, 2001, 09:41
Alton J. Reich
Selina,
I have personally used CFD-GEOM, Gridgen, and Gridpro for generating meshes. Most grid generation packages (CFD-GEOM, Gridgen, and many others) work based on the same principals of "bottom up" grid generation. In this system the user must first generate the geometry (either in the grid generation package, or in a CAD package). Then the user defines mesh primatives such as edges and faces of grid. Finally, the faces are used to generate either structured (hex) or unstructured (tet, prism, or hex) volume grids.
Generally speaking, there is not a great deal of difference between these grid generation packages. Personal preference plays a large role in which one you think is "best". I may think that one is better because the controls are more intuitively laid out. John may think that the layout of the one I like is confusing, and he may perfer another because it has a wider range of features.
GridPro is the only one that is significantly different, and when I worked at Electric Boat we worked fairly closely with the developers to make significant improvements. In 1995-ish when I first used this code it was almost impossible to get a good grid. By 1997, it just took a long time. To generate a grid in Gridpro, the user defines the basic shape of the grid, and reads in surfaces that the grid should conform to. The grid is actually generated by an iterative projection and smoothing technique. It can generate nicely smoothed, conformal grids, but the iterative nature of the process requires patience on the part of the user. I'd also like to qualify this by saying that it's been several years since I've last used Gridpro.
Alton
Old   March 22, 2001, 13:43
John C. Chien
(1). In 3-D, to create a four-sided tet-cell, you need to define four points. You can put three points on the boundary and grow the cell by adding the last point in the flow field. (2). Once you have that, you can connect lines between points to form a cell. I think, you can teach any high school kid to do that easily. All you need is the location of the four points, (x1,y1,z1), (x2,y2,z2), (x3,y3,z3) and (x4,y4,z4). (3). You can also fix the distance between two points and build the cell one-by-one until you reach the other boundary. At that point, you can change the size.(4). For six-sided hexa cell, you can combine several tet-cells to form one hexa cell. Or you can define eight points to create a new one. The process is like the kids toy "lego". (5). Beyond that point (the toy exercise), you have additional requirements such as the accuracy of mesh at the boundary wall(a straight line of the cell can not represent the curved line of the boundary or walls) and the consistency with the solution (which is still an unknown),etc... (6). So, the mesh itself is an approximation to the real geometry and a starting point to a solution. Before you reach the mesh independent solution, there is a long way to go. Mesh generation? ask Lego kids.
Old   March 24, 2001, 22:25
clifford bradford
John, I think what Selina wants if for you to tell her what's your favorite mesh generator.
Old   September 6, 2011, 13:46
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Sad! I have never played Lego before.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 16:50
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
1.6-ext compilation flowris OpenFOAM 18 March 21, 2011 12:01
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
