MULTIGRID 3D
Old   June 17, 2005, 09:38
Default MULTIGRID 3D
Davoche
Hi, i'm using FMG ( Full Multigrid Method ) from Numerical Recipes.
I will adapt this for a 3D stretched Poisson equation but for the moment I'm in trouble with the simple 2D regular Laplace equation: Laplacian[T(x,y)]=0.
The problem is about the inhomogeneous boundary condition. In fact, I want to simulate the statiationnary problem of heated wall:[T(x=0,y)]=1 and :[T(x=1,y)]=0. As mentionned in the Num.Rec., I have introuduced the boundary condition in the source term (R.H.S.), but it doesn't work at all [T=0] everywhere.
Any Ideas ????
Old   June 17, 2005, 12:05
Default Re: MULTIGRID 3D
Junseok Kim
Which language are you using for this code? I may help you.
Old   June 17, 2005, 12:41
Davoche
Thanks I'm using Fortran 77 (or 90).
Old   June 17, 2005, 14:20
Junseok Kim
It is hard to see the code problem, would you send the file to me, I will take a look at it to find bugs.
Old   June 18, 2005, 16:55
Junseok Kim
parameter (n=65)
real*8 T
dimension T(n,n) c c x: c
ncycle=2
do 5 j=1,n
do 5 i=1,n
T(i,j)=0.d0 !=> temporal equilibrium qd t->infini
5 continue c
do 7 i=1,n
T(i,1)=-1.d0 !=> Boundary condition applied to the lower wall
7 continue ! The wall is heated at T(i,j=1)=1.
Take a look at the Numerical Recipes again, and try below,
do 7 i=1,n
T(i,2)=-1.d0
Old   June 19, 2005, 12:31
Davoche
Thanks, I've tried it... But there still problems I try to solve.
a) The solution doesn't correspond to boundary I fix: T=1.
b) The solution depends on the Grid size !!!
Old   June 19, 2005, 20:24
Junseok Kim
1) After you calculate the solution, you need to add T=1 at the boundary.
2) The problem itself is singular problem, why don't you try it with known solution to test the code.
For example,
T(x,y)=(x**2-x**4)(y**4-y**2) and set the source term as Laplacian of this T and solve the Poisson equation and compare with numerical solution and exact solution.
Old   June 20, 2005, 10:02
Davoche
Thank you. I've already fixed T=1 at the boundary but it doesn't appears in calculation so...
I have test the code with your exemple and it works well. So it was clearly a problem of singularity.
A question arises :
I'm trying to implement this Multigrid method to resolve a Pojection Pressure equation ( 2nd step of fractional Step Method in Navier Stokes ). But in wall bounded flow, it seems to discarded the boundary condition. I'm a little bit confused with the implicit 0 boundary condition.
Thank you one more time
Old   June 20, 2005, 11:06
Junseok Kim
If you use piecewise linear element in the pressure solver, and it turns out using 9 point finite difference scheme for Poisson solver, the zero boundary condition is obtained by zero Neumann boundary condition for the pressure field. The zero Neumann boundary condition for the pressure field implicitly given by using a test function, which is zero compact support in the boundary points.
LES by Multigrid mnabi Main CFD Forum 8 July 11, 2009 20:21
multigrid sureshkumar Main CFD Forum 0 June 9, 2006 01:20
Multigrid method Suresh kumar Main CFD Forum 1 April 24, 2006 20:07
MULTIGRID at the wall Jim Main CFD Forum 0 February 19, 2003 12:22
Multigrid applied to k-e models Paulo Zandonade Main CFD Forum 9 May 24, 1999 08:10
