October 6, 2011, 09:00 |
CFD Project
ankit chauhan
Rep Power: 14 |
Hi everyone please advise me a topic that I can finalize for my university minor project on CFD using gambit and fluent.
Thanx in advance. |
October 10, 2011, 01:06 |
you mean is that someone can teach you about the fluent and Gambit?
October 10, 2011, 09:47 |
ankit chauhan
Rep Power: 14 |
@ wangyifei you mean is that someone can teach you about the fluent and Gambit?
NO I just need an idea and some relevant details and rest I will do myself. |
October 10, 2011, 09:49 |
ankit chauhan
Rep Power: 14 |
October 10, 2011, 09:50 |
ankit chauhan
Rep Power: 14 |
October 10, 2011, 10:52 |
Detached eddy simulation is new relatively new development in CFD, lies in between RANS and LES. In other words it is RANS in boundary layer (you can use more stretched mesh) and switches to the LES (automatically) in the far field. So meshing requirements are bit higher than RANS, but very very less than the Large Eddy Simulation (LES). Disadvantages are:
1. Unsteady problem 2. Requires more RAM 3. More computational time As you know that Flat plate and Circular cylinder very classical fluid mechanics problems. You can find very good details in any fluid mechanics book or use Google. |
October 11, 2011, 02:38 |
#9 |
ankit chauhan
Rep Power: 14 |
October 11, 2011, 09:07 |
#10 |
I can propose you something which is not new from research side, but can be very useful from ingeneering/user point of view.
Recently, I have encountered problem analyzing unconventional airfoils at low reynolds numbers of order 10^5. At such reynolds numbers one has huge problems with turbulence modelling, as flow is neither fully turbulent nor laminar: there are separation bubbles and transition to turbulence. There is a good piece of software, called x-foil, which copes much more better with such analysis than any cfd-sofware, but it only works for conventional airfoils. In my case I was analysing airfoils with backward facing step on the surface, so I had to use LES with gambit/fluent: I had an idea to write an authomatic software, say in mathlab or scilab, that generates journal files for gambit and fluent so that other non-ultra-specialist people could use them, but had no enough time to finish the project. In more detail: you can write a program in matlab or scilab (better scilab since it is free), that takes airfoil (or multiple airfoil) coordinates, reynolds number and angle of attack/free stream turbulence intensity, and then generates gambit and fluent journal files for LES simulations. If you write such a program and then post it somewhere, thousands of persons will be grateful to you, and still such a project looks like an excercise. I could pass you scilab/journal gambit/fluent files I have stopped at. Truffaldino |
fluent, gambit, project |
CFD related undergraduate project?? | digant26290 | Main CFD Forum | 9 | July 25, 2011 14:36 |
cfd project | akj | Main CFD Forum | 0 | June 18, 2011 08:04 |
Under Graduate project in CFD | Monali Gupta | FLUENT | 1 | February 13, 2008 16:15 |
Plz tell @ CFD Project | CV | Main CFD Forum | 0 | February 6, 2006 03:00 |
Can we quantify the fruits of CFD? | Brady Brown | Main CFD Forum | 14 | December 15, 1999 09:42 |
