Optimization using Steepest Descent Algorithm
Old   February 19, 2015, 05:07
Default Optimization using Steepest Descent Algorithm
Vibhor pandey
Vibh is on a distinguished road
Hi! I am trying to Optimize the shape of a diffuser in order to reduce the Pressure Drop across it. To do so, I am using Adjoint Flow Solver in STAR CCM+ which gives me the Sensitivities(Gradients, i.e. X,Y and Z Pressure Drop Derivative). I use that data to generate new points using the Steepest Descent Algorithm with the help of a formula Xnew = Xold - (Step Size * X Gradient) and respectively for Y and Z.
The problem which I'm facing is finding the Global Minimum of the Solution. Sometimes the Initial Geometry lies somewhere around the local minimum which doesn't leaves much scope for improvement.
Can anyone please put forward some suggestions?
Thank you!
Vibh is offline   Reply With Quote
adjoint, algorithm, optimization, star ccm+
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 10:31
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
whats the general way to add an optimization algorithm? immortality OpenFOAM Running, Solving & CFD 5 March 29, 2013 01:22
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 08:57
steepest descent and conjugate gradient devalpandya Main CFD Forum 0 April 23, 2009 04:25
