Gallalian Invariance -------Again
Old   June 17, 2005, 04:43
Default Gallalian Invariance -------Again
David Liu
The first law of thermodynamics is a basic law. But it does NOT obey Gallalian Invariance.
This is because it deals with the kinetic energy which is not of Gallalian Invariance.
This law: W+Q=(K2+P2)-(K1+P1)
W: work; Q: Heat input/out to the system; K: kinetic energy; P: potential energy.
You will find that the work needed is different in two inertia frame if you increase the total energy in same amount for a system.
Old   June 17, 2005, 08:07
Default Re: Gallalian Invariance -------Again
versi
K, the kinetic energy, is interpreted as from random thermal motion of molecues, it does not = (thermal velocity + velocity of inertial frame)^2 /2. by this interpretation, work in two different inertia frame is the same.
Old   June 20, 2005, 01:01
David Liu
Posted By: David Liu Date: Sun, 19 Jun 2005, 10:58 p.m.
In Response To: Re: Gallalian Invariance (Tom) ================================================== == Is NS equation of Galilean Invariance? ================================================== ==
For steady flow, NS equation in Vector form:
V . Grad V = Grad p + Div. T
After changing to another inertia system, V changed, but Grad V, Grad p, Div.T do not change their value in the new system.
So that the above equation is not correct any more. That is, left side is not equal to right side.
Is it right?
Thanks, David
Invariance of relative total temperature jpo FLUENT 0 June 9, 2011 15:39
Gallalian Invariance Wayne Main CFD Forum 12 June 20, 2005 04:23
Asymptotic (invariance) assumption in turbulence vasanth Main CFD Forum 0 October 24, 2004 11:14
Riemann Invariance Javier Main CFD Forum 2 March 25, 1999 08:02
Gausian Invariance Tom Main CFD Forum 1 August 12, 1998 15:04
