CFD capabilities
Old   October 18, 2011, 06:24
Default CFD capabilities
JABM is on a distinguished road
Hi there,
I have a client that would like to install a natural gas pipe. The pipe will be made from PE pipe using diameters between 180mm-400mm and will be approximately 20km long. The client would like to have a 3D model of the entire pipe created, and then analyse the model using CFD to work out pressure loss along the length of the pipe.
I have very limited experience using CFD so I wasn't too sure about this, but my first thought was that using CFD for this purpose would be a waste of time due to the fact that it would take a very long time to model the entire 20km pipe, and the pressure loss results that we would obtain would likely not be significantly different than those obtained using simple hand calculations. And would a CFD simulation even work at all for a model of this size, without needing some sort of super-computer? Does anyone have any thoughts on this?
Thanks for your help,
James
JABM is offline   Reply With Quote
Old   October 18, 2011, 07:05
Charles
CapSizer is on a distinguished road
Originally Posted by JABM View Post
Hi there,
James
Sounds like total overkill, and probably nowhere near as effective as purpose-written pipe network analysis software.
CapSizer is offline   Reply With Quote
Old   October 18, 2011, 09:24
Graham81 is on a distinguished road
If client insists on the use of CFD, consider modeling a pipe section to pinpoint where the flow profile is fully developed (there are empirical correlations to use as a first estimate) and then some lengths to find a lossfactor per length scale. Really dont see the added value of CFD here either though.
Graham81 is offline   Reply With Quote
Old   October 19, 2011, 14:55
Erik
evcelica is on a distinguished road
Its you job as the consultant to tell them CFD is not needed in this case, and would be a waste of time. Pipe flow has been well studied and one can make use of compressible flow equations quite easily, This includes K-factors for bends, reducers, roughness of the pipe wall ect. Plus then you can calculatee curves for the pressure drop depending on the temperature, flow rate ect.
evcelica is offline   Reply With Quote
Old   October 20, 2011, 22:53
Default Just Reiterating
Lucky
Hi James, I will just say, for sake of further support,
Don't bother with CFD.
It will not tell you anything that you don't already know. Seriously, it's just a pipe, what can happen? Simple, time-tested and well proven results from fluids are much more practical (and reliable). CFD would be too cumbersome to actually even implement all real life factors (surface roughness, junction effects, did the sun even come up on that day?). Definitely no to CFD if all that they are interested in is pressure loss.
Also, given the scope of the problem. I seriously doubt that the customer can even afford ($$) to perform the CFD
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD codes with MHD capabilities Nicole Main CFD Forum 1 May 18, 2002 05:58
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
