timestep for unstructured grid
Old   June 22, 2005, 15:56
Default timestep for unstructured grid
ma
What is the best way to calculate the CFL-based timestep in an unstructured grid? Thanks a lot!
ma
Old   June 23, 2005, 13:06
Default Re: timestep for unstructured grid
ganesh
Dear ma,
The CFL based time step in an unstructured grid can be calculated as follows.
dt = CFL * sl/[abs(q)+a]
where dt is the time step
CFL is the Courant number
sl is some characteristic length, typically the square root of area in 2D or cube root of volume in 3D q is the total velocity( q=sqrt(u**2 + v**2) ) where u and v are the velocity components(2D). and a is the sonic speed.Note that [abs(q)+a] is the largest eigen value.
Note that dt is calculated for ecah cell in the domain.
It is possible to use two types of time stepping procedures.
1. Global time stepping.
The minimum of dt calculated for all cells is used for the stepping in the entire domain. As you can easily appreciate, the convergence would be slow in this case.
2. Local time stepping.
The dt calculated in each cell is used for stepping in the respective cells. A good acceleration convergence techinique esp. for viscous flows where you experience grid-induced stiffness. This is generally recommended for steady flow problems. In conjuction with implicit schemes, is a very fast convergence prompting tool. However, cannot be used for unsteady flows as such.
Hope this information helps.
Regards,
Ganesh
Old   June 24, 2005, 14:05
Jeff Moder
A slight variation on
... dt = CFL * Lref / max_eigenvalue
for a cell-centered finite volume method is
... dt = CFL * vol(i) / [sum_{k=1,nfaces(i)} lambdaA(k)]
where
i = cell index
k = face index
nfaces(i) = number of faces for cell i
lambda(k) = u(k)*Ax(k) + v(k)*Ay(k) + w(k)*Az(k) + a(k)*A = max eigenvalue based on (velocity dot area vector)
u,v,w = Cartesian velocity components
Ax,Ay,Az = Cartesian component of area vector normal to face k
A = sqrt(Ax**2 + Ay**2 + Az**2) = area of face k
a(k) = speed of sound based on local properties of face k
Old   July 4, 2005, 12:47
ma
Thanks a lot for these details.
- ma
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
