Lid driven flow in shallow rectangular domain issues, MATLAB
Old   November 10, 2011, 20:41
Default Lid driven flow in shallow rectangular domain issues, MATLAB
Peter
new_at_this is on a distinguished road
So i'm modifying the code made by Benjamin Seibold to deal with shallow rectangular cavities for lid driven flows. Original code is located here and is 6.7 under MATLAB codes along with associated documentation.
http://www-math.mit.edu/cse/
My problem is that the pressure correction step is not enforcing a divergence free velocity field.
To change to a rectangular domain, I have non dimensionalized using the following:
u^* = \frac{u}{U}\hspace{5 mm} v^* = \frac{vL}{UH} \hspace{5 mm} x^* = \frac{x}{L} \hspace{5 mm}y^* = \frac{y}{L} \hspace{5 mm} t^* = \frac{tU}{H} \hspace{5 mm} p^* = \frac{p + p_\infty}{\rho U^2}
which gives the N-S equations
\frac{\partial u}{\partial t} + u \frac{H}{L} \frac{\partial u}{\partial x}  + v \frac{H}{L} \frac{\partial u}{\partial y} = -\frac{H}{L} \frac{\partial P}{\partial x} + \frac{1}{Re}\left( \frac{H^2}{L^2} \frac{\partial ^2 u}{\partial x^2} +\frac{\partial ^2 u}{\partial y^2} \right)
\frac{\partial v}{\partial t} + u \frac{H}{L} \frac{\partial v}{\partial x}  + v \frac{H}{L} \frac{\partial v}{\partial y} = -\frac{L}{H} \frac{\partial P}{\partial y} + \frac{1}{Re}\left( \frac{H^2}{L^2} \frac{\partial ^2 v}{\partial x^2} +\frac{\partial ^2 v}{\partial y^2} \right)
Here is the modified code that I have so far. It plots the stream lines, the u and v velocity at different vertical slices of the rectangle and prints the maximum divergence in the field.
if you feel like running it, just copy paste to matlab m file, save and hit F5 and everything should work. By adjusting AR at the top, you can change the size of the rectangle where AR = H/L
If the AR is 1, code runs fine and quantitative values have been compared with ghia and do not show any significant errors. Any one know whats wrong??????
Thanks
function []=debug()
clear all
close all
clc
%% Paramters
AR=0.5;                                        % Aspect Ratio
Pe=500;                                      % Peclet Number
Re = 100;                                    % Reynolds number
tf = 40e-0;                                  % final time
dt = 0.01;                                   % time step
lx = 1;                                      % width of non-D domain
ly = 1;                                      % height of nond-D domain
hxmax=0.025;                                  % Maximum x grid size
hymax=0.025;                                  % Maximum y grid size
ny=ceil(1/hymax);                            % Number of y grid points
nx=ceil(1/AR/hxmax);                         % Number of x grid points
hy=1/ny;                                     % Actual y grid size
hx=1/nx;                                     % Actual x grid size
% Dimensional Variables
H=1;                                       % Height of droplet
L=H/AR;                                      % Length of droplet
dy=H/ny;                                     % Width of y grid
dx=L/nx;                                     % Width of x grid
dimx(1:nx+1)=(0:nx)*dx;                      % X coordinates
dimy(1:ny+1)=(0:ny)*dy;                      % Y coordinates
% Fluid Properties
rho=1000;                                    % Density
mu=0.86e-3;                                  % Viscosity
c=4184;                                      % Specific heat
k=0.6;                                       % Thermal conductivity
ubulk=(Re*mu)/(rho*H);                       % Bulk Velocity
nsteps = 10;  % number of steps with graphic output
nt = ceil(tf/dt); dt = tf/nt;                % number of time iterations
x = linspace(0,lx,nx+1);                     % non-D x coordinates
y = linspace(0,ly,ny+1);                     % non-D y coordinates
[X,Y] = meshgrid(y,x);
% initial conditions
U = zeros(nx-1,ny); V = zeros(nx,ny-1);
% boundary conditions
uN = x*0+1; uN = [0 uN(2:end-1) 0];
uS = x*0; uS = [0 uS(2:end-1) 0];
uW = avg(y)*0;
uE = avg(y)*0;
vN = avg(x)*0;
vS = avg(x)*0;
vW = y*0;
vE = y*0;
%% Time stepping
Ubc = dt/Re*([2*uS(2:end-1)' zeros(nx-1,ny-2) 2*uN(2:end-1)']/hy^2+...
      [uW;zeros(nx-3,ny);uE]/hx^2);
Vbc = dt/Re*([vS' zeros(nx,ny-3) vN']/hy^2+...
      [2*vW(2:end-1);zeros(nx-2,ny-1);2*vE(2:end-1)]/hx^2);
fprintf('initialization')
Lp = kron(speye(ny),AR*K1(nx,hx,1))+kron((1/AR)*K1(ny,hy,1),speye(nx));
Lp(1,1) = 3/2*Lp(1,1);
perp = symamd(Lp); Rp = chol(Lp(perp,perp)); Rpt = Rp';
Lu = speye((nx-1)*ny)+dt/Re*(kron(speye(ny),AR^2*K1(nx-1,hx,2))+...
     kron(K1(ny,hy,3),speye(nx-1)));
peru = symamd(Lu); Ru = chol(Lu(peru,peru)); Rut = Ru';
Lv = speye(nx*(ny-1))+dt/Re*(kron(speye(ny-1),AR^2*K1(nx,hx,3))+...
     kron(K1(ny-1,hy,2),speye(nx)));
perv = symamd(Lv); Rv = chol(Lv(perv,perv)); Rvt = Rv';
Lq = kron(speye(ny-1),K1(nx-1,hx,2))+kron(K1(ny-1,hy,2),speye(nx-1));
perq = symamd(Lq); Rq = chol(Lq(perq,perq)); Rqt = Rq';
fprintf(', time loop\n--20%%--40%%--60%%--80%%-100%%\n')
for k = 1:nt
   % treat nonlinear terms
   gamma = min(1.2*dt*max(max(max(abs(U)))/hx,max(max(abs(V)))/hy),1);
   Ue = [uW;U;uE]; Ue = [2*uS'-Ue(:,1) Ue 2*uN'-Ue(:,end)];
   Ve = [vS' V vN']; Ve = [2*vW-Ve(1,:);Ve;2*vE-Ve(end,:)];
   Ua = avg(Ue')'; Ud = diff(Ue')'/2;
   Va = avg(Ve);   Vd = diff(Ve)/2;
   UVx = diff(Ua.*Va-gamma*abs(Ua).*Vd)/hx;
   UVy = diff((Ua.*Va-gamma*Ud.*abs(Va))')'/hy;
   Ua = avg(Ue(:,2:end-1));   Ud = diff(Ue(:,2:end-1))/2;
   Va = avg(Ve(2:end-1,:)')'; Vd = diff(Ve(2:end-1,:)')'/2;
   U2x = diff(Ua.^2-gamma*abs(Ua).*Ud)/hx;
   V2y = diff((Va.^2-gamma*abs(Va).*Vd)')'/hy;
   U = U-dt*AR*(UVy(2:end-1,:)+U2x);
   V = V-dt*AR*(UVx(:,2:end-1)+V2y);
   % implicit viscosity
   rhs = reshape(U+Ubc,[],1);
   u(peru) = Ru\(Rut\rhs(peru));
   U = reshape(u,nx-1,ny);
   rhs = reshape(V+Vbc,[],1);
   v(perv) = Rv\(Rvt\rhs(perv));
   V = reshape(v,nx,ny-1);
   % pressure correction
%    rhsv = reshape((diff([uW;U;uE])/hx+diff([vS' V vN']')'/hy),[],1);
%    rhsv = rhsv.*AR^2;
%    rhsu = reshape((diff([uW;U;uE])/hx+diff([vS' V vN']')'/hy),[],1);
%    pu(perp) = -Rp\(Rpt\rhsu(perp));
%    pv(perp) = -Rp\(Rpt\rhsv(perp));
%    Pu = reshape(pu,nx,ny);
%    Pv = reshape(pv,nx,ny);
%    U = U-AR*diff(Pu)/hx;
%    V = V-(1/AR)*diff(Pv')'/hy;
   rhs = reshape(diff([uW;U;uE])/hx+diff([vS' V vN']')'/hy,[],1);
   p(perp) = -Rp\(Rpt\rhs(perp));
   P = reshape(p,nx,ny);
   U = U-diff(P)/hx;
   V = V-diff(P')'/hy;
   % visualization
   if floor(25*k/nt)>floor(25*(k-1)/nt), fprintf('.'), end
   if k==1|floor(nsteps*k/nt)>floor(nsteps*(k-1)/nt)
      % stream function
      rhs = reshape(diff(U')'/hy-diff(V)/hx,[],1);
      q(perq) = Rq\(Rqt\rhs(perq));
      Q = zeros(nx+1,ny+1);
      Q(2:end-1,2:end-1) = reshape(q,nx-1,ny-1);
%       clf, contourf(avg(x),avg(y),P',20,'w-'), hold on
      contourf(dimx,dimy,Q',20,'w-');
      Ue = [uS' avg([uW;U;uE]')' uN'];
      Ve = [vW;avg([vS' V vN']);vE];
      Len = sqrt(Ue.^2+Ve.^2+eps);
%       quiver(x,y,(Ue./Len)',(Ve./Len)',.4,'k-')
      hold off, axis equal, axis([0 L 0 H])
%       p = sort(p); caxis(p([8 end-7]))
      title(sprintf('Re = %0.1g   t = %0.2g',Re,k*dt))
      drawnow
   end
end
fprintf('\n')
ufield=Ue';
vfield=Ve';
ulab=abs(ufield-1);
mid=ceil((nx+1)/2);
quart=ceil(1*(nx+1)/100);
if quart==1
    quart=2;
end
third=ceil(5*(nx+1)/100);
next=ceil(1*(nx+1)/5);
figure(3)
plot(ulab(:,quart),y,ulab(:,third),y,ulab(:,next),y,ulab(:,mid),y)%,ulab(:,end-quart),y)
legend('0.02H','0.1H','0.4L','H','other','location','West')
title('U profiles')
figure(4)
plot(vfield(:,quart),y,vfield(:,third),y,vfield(:,next),y,vfield(:,mid),y)%,vfield(:,end-quart),y)
title('V profiles')
%% Divergence Test
div=divergence(ufield,vfield);
max_div = max(max(div(2:end-1,2:end-1)))
function B = avg(A,k)
if nargin<2, k = 1; end
if size(A,1)==1, A = A'; end
if k<2, B = (A(2:end,:)+A(1:end-1,:))/2; else, B = avg(A,k-1); end
if size(A,2)==1, B = B'; end
function A = K1(n,h,a11)
% a11: Neumann=1, Dirichlet=2, Dirichlet mid=3;
A = spdiags([-1 a11 0;ones(n-2,1)*[-1 2 -1];0 a11 -1],-1:1,n,n)'/h^2;
new_at_this is offline   Reply With Quote
Two sided Lid Driven Cavity Flow Perumal Main CFD Forum 1 January 22, 2007 13:27
lid driven cavity ani Main CFD Forum 3 April 2, 2006 13:27
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
