finite element method for the Shallow Water Equations help |
December 4, 2011, 21:28 |
John Smith
I try to solve the Shallow Water Equations using finite element methods. Can anyone explain me how to treat nonlinear terms? The problem is that we can write linear terms as matrix-vector multiplication where matrix is independent on time. For example for the height field h we have after getting the Galerkin equation by multiplying on test function and integrating over domain we will get the term like or in the matrix form Hence we compute the matrix only once and then multiply by updated coefficient vector But how to deal with the terms like $uh$? where u is the velocity after getting the Galerkin equation this will be like How these can be represented in the matrix form in order not to compute all these integrals on each timestep? Last edited by alvesker; December 4, 2011 at 21:54. Reason: typo |
December 5, 2011, 02:31 |
Dear alvesker,
you don't have to write the FEM approximated form of each parameter is more accurate, though, I would suggest writing the the mean value of those parameters to simplify the weak form. about the integration on each time step it depends on the grid form you are using to split the domain. Last edited by seyedashraf; December 5, 2011 at 04:52. |
December 5, 2011, 04:48 |
John Smith
Dear seyedashraf,
Thanks for the quick reply. Can you explain what do you understand by the mean value? is it like the following? and how write it to the terms like where u, h are the velocity component and height field So if apply the FEM we have what is the average in the case when in the multiplication one of unknows one contain gradient (we have these in the advection formulation) Last edited by alvesker; December 5, 2011 at 23:20. Reason: add |
December 5, 2011, 05:01 |
John Smith
the grid form - I use triangular grid
What is C.V. based finite element method | C-H Kuo | Main CFD Forum | 4 | September 19, 2022 14:06 |
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method | solemnpriest | Main CFD Forum | 3 | August 12, 2013 11:00 |
OpenFOAM-extend, Finite Element Method (FEM) | Martin80 | OpenFOAM Programming & Development | 1 | December 3, 2011 06:28 |
finite element method | harten | Main CFD Forum | 0 | November 1, 2007 05:37 |
BCs of hyperbolic Shallow Water Equation | Kang, S. K. | Main CFD Forum | 4 | November 21, 2000 21:20 |
