naming wall patches in OpenFoam
Old   December 6, 2011, 11:13
Default naming wall patches in OpenFoam
musaddeque hossein
musahossein is on a distinguished road
Dear all:
I am modeling a rectangular tank with patch names as follows:
vertices
(-0.5 -20 -10.0) // Vertex back lower left corner = 0
(-0.5 20 -10.0) // Vertex back lower right corner= 1
(-0.5 20 10.0) // Vertex back upper right corner= 2
(-0.5 -20 10.0) // Vertex back upper left corner = 3
(0.5 -20 -10.0) // Vertex front lower left corner = 4
(0.5 20 -10.0) // Vertex front lower right corner= 5
(0.5 20 10.0) // Vertex front upper right corner = 6
(0.5 -20 10.0) // Vertex front upper left corner =7
blocks
// block0
hex (0 1 2 3 4 5 6 7)
(40 40 1)
simpleGrading (1 1 1)
//patches
boundary
lowerWall
type patch;
faces
(0 1 5 4)
rightWall
type patch;
faces
(1 2 6 5)
atmosphere
type patch;
faces
(2 3 7 6)
leftWall
type patch;
faces
(0 4 7 3)
frontAndBack
type Empty;
faces
(4 5 6 7)
(0 3 2 1)
blockMesh runs ok and gives the following output:
musa@musa-Satellite-M35X:~/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D$ blockMesh
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.1-51f1de99a4bc
Exec : blockMesh
Date : Dec 06 2011
Time : 10:16:35
Host : musa-Satellite-M35X
PID : 2959
Case : /home/musa/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/musa/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/polyMesh/blockMeshDict"
No non-linear edges defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
There are no merge patch pairs edges
Writing polyMesh
Mesh Information
boundingBox: (-0.5 -20 -10) (0.5 20 10)
nPoints: 3362
nCells: 1600
nFaces: 6480
nInternalFaces: 3120
Patches
patch 0 (start: 3120 size: 40) name: lowerWall
patch 1 (start: 3160 size: 40) name: rightWall
patch 2 (start: 3200 size: 40) name: atmosphere
patch 3 (start: 3240 size: 40) name: leftWall
patch 4 (start: 3280 size: 3200) name: frontAndBack
End
But when I try to view it in paraFoam, I get the following error message:
musa@musa-Satellite-M35X:~/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D$ paraFoam
created temporary 'sloshingTank2D.OpenFOAM'
--> FOAM FATAL IO ERROR:
keyword lowerWall is undefined in dictionary "/home/musa/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/0/U::boundaryField"
file: /home/musa/OpenFOAM/musa-2.0.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/0/U::boundaryField from line 25 to line 26.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 461.
FOAM exiting
It appears that my attempt to view the mesh in paraFoam is affecting U in folder 0 which contains:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
walls
type movingWallVelocity;
value uniform (0 0 0);
How can I correct this? Any help will be greatly appreciated.
musahossein is offline   Reply With Quote
patch type
Wall function BC:s on regionCouple patches Ola Widlund OpenFOAM Programming & Development 2 February 1, 2013 07:24
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
