About the createPatchDict
Old   December 7, 2011, 11:31
Default About the createPatchDict
flotran is on a distinguished road
Dear all,
Could you explain the "neighbourPatch" in createPatchDict and how to select?
The reatePatchDict :
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
// a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
// is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
// and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
// setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
// "face 0 area does not match neighbour 2 by 0.0100005%"
// " -- possible face ordering problem."
// - in polyMesh/boundary file:
// - loosen matchTolerance of all cyclics to get case to load
// - or change patch type from 'cyclic' to 'patch'
// and regenerate cyclic as above
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
// with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
// Name of new patch
name cyc_half0;
// Dictionary to construct new patch from
patchInfo
type cyclic;
neighbourPatch cyc_half1;
// Optional: explicitly set transformation tensor.
// Used when matching and synchronising points.
transform rotational;
rotationAxis (1 0 0);
rotationCentre (0 0 0);
// transform translational;
// separationVector (1 0 0);
// Optional non-default tolerance to be able to define cyclics
// on bad meshes
//matchTolerance 1E-2;
// How to construct: either from 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches. Wildcards allowed.
patches (periodic1);
// If constructFrom = set : name of faceSet
set f0;
name cyc_half1;
patchInfo
type cyclic;
neighbourPatch cyc_half0;
rotationAxis ( 0 0 1 );
rotationCentre ( 0.3 0 0 );
patches (periodic2);
set f0;
flotran is offline   Reply With Quote
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
[mesh manipulation] CreatePatch to create cyclic boundary sbence OpenFOAM Meshing & Mesh Conversion 18 August 30, 2012 06:51
[Commercial meshers] cyclic multiedge BC karamiag OpenFOAM Meshing & Mesh Conversion 1 June 30, 2010 11:24
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 04:35
