Problems about fluid-structure interaction
Old   December 7, 2011, 12:45
Default Problems about fluid-structure interaction
min xu
min_nmsu is on a distinguished road
I am solving a fluid-structure interaction problems, in which fluid has different density as solid. This problem is a little bit same as multiphase flow problem. The code turns to be unstable when density ratio reaches up to 100. I am wonder whether the conservative form of governing equation is better than the non-conservative one?
min_nmsu is offline   Reply With Quote
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
Fluid Structure Interaction shaan Main CFD Forum 2 February 9, 2007 08:03
