1D Stress Tensor
Old   December 17, 2011, 12:01
Default 1D Stress Tensor
Hooman is on a distinguished road
What does the second and third terms of the stress tensor reduce to when dealing with the 1D compressible and viscous flow? (So only the pressure term remains)
stress tensor = -P +2*mu*D- 2/3*mu*div(v)
where D = the rate of strain deformation = 1/2*(grad(v)+grad(v)^T)
Thanks in advance!
Hooman is offline   Reply With Quote
Old   December 17, 2011, 12:10
cfdnewbie
cfdnewbie is on a distinguished road
well, just set all the derivatives wrt y and z to zero, so sth like div(v) will become du/dx...
cfdnewbie is offline   Reply With Quote
Old   December 19, 2011, 07:32
Hi, Yeah I think I know how to get it mathematically:
stress tensor = -P +1/3*du/dx
I needed to check this as I was not sure what happens physically in a 1D case where a force is applied in the same plane as the fluid velocity (say x-direction).
Also the equation originally involves two viscous stress: the dynamic viscosity which relates stress two linear deformations and the second stress which relates stress to volumetric deformations. And I was not sure if the second one will be present in a 1D case.
I would appreciate any references to 1D shear stress equations. I have found one but I can't quite derive the same equation they have so not sure if its correct.
Thank you in advance!
Old   December 21, 2011, 04:01
cfdnewbie
http://www.jstor.org/pss/2157934
not sure if this is what you are looking for, though....
Thread Tools
Trackbacks are On
post-processing utility R, calculating Reynolds stress tensor volker OpenFOAM Post-Processing 5 May 2, 2013 13:09
Reynolds Stress Tensor Sergio13 OpenFOAM 6 April 13, 2011 03:23
How to modify the stress tensor of momentum eqns. Jason FLUENT 1 November 26, 2010 05:20
stress tensor at the wall voytex Main CFD Forum 0 April 26, 2004 10:24
Stress tensor components ap FLUENT 0 February 26, 2004 12:16
