Equillibrium Reactions
Old   September 26, 2011, 01:34
Default Equillibrium Reactions
sulabh gupta
sulabh gupta is on a distinguished road
Hi everyone
I have just started using CFD ACE. I have a small query regarding how to set a equillibrium reaction in CFD ACE.
Thank you
sulabh gupta is offline   Reply With Quote
Old   January 17, 2012, 03:43
Majid S.
majid_esi is on a distinguished road
sure let me know if its not too late
Majid
majid_esi is offline   Reply With Quote
Old   January 17, 2012, 03:56
sulabh gupta
i got that dude .... facing some other problem related to volume reaction along with surface reaction .....
Old   January 17, 2012, 03:59
Majid S.
and whats that?
Old   January 17, 2012, 04:25
sulabh gupta
If you have to solve for both reactions taking place in the volume of the reactor and one reaction on the surface of the reactor than how to proceed ...
Old   January 17, 2012, 05:25
Majid S.
well, you can define the surface reaction on the boundary condition under chemical rex tab and volume reaction can be defined in volume condition again in chemical reaction tab
Old   January 17, 2012, 06:46
sulabh gupta
i knw that but the solution is not converged ....the reaction happens in some fractions of the reactor volume...
Old   January 17, 2012, 13:47
Rahul
Rahul_W is on a distinguished road
Is it Instantaneous reaction problem?
Rahul_W is offline   Reply With Quote
Old   January 17, 2012, 23:50
sulabh gupta
No you have a reaction rate constant .... we can also take equilibrium reaction rate constant....
Old   January 18, 2012, 12:52
Rahul
Its is difficult to answer this query without looking into the problem.
Old   January 20, 2012, 00:27
sulabh gupta
The problem is I am simulating a Chemical Vapor Deposition Reactor for production of silicon. The reactor configuration is such that you have an U shape rod where deposition takes place .Its basically Seimens process for production of Silicon.
the surface reaction is
SIHCL3+H2->SI(B)+3HCL
along with this there are several volume reactions one of which is
SIHCL3->HCL+SICL2
how to proceed in this case .
Ty
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 11:11
Both volumetric and surface reactions Leverkin FLUENT 2 July 15, 2009 17:07
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
catalytic reactions - solid species? Claud FLUENT 0 February 5, 2008 02:41
Duplicate/enhanced reactions in Chemkin? PattiMichelle Phoenics 0 March 2, 2002 17:19
