August 24, 2005, 17:06 |
Gradient Diffusion
can some one explain gradient and counter gradient diffusion to me.
how do we model them??? |
August 24, 2005, 21:24 |
Re: Gradient Diffusion
Gradient diffusion says that the variable "moves" from areas of high concentration to areas where the concentration is lower. So if you've got, say, a region of high temperature (hot brick) in a domain (bucket of water), the temperature will fall in the hot region and increase in the rest of the domain. If you let it go for a "long time", temperature everywhere will be the same, i.e. the gradient will fall to zero. In short, the (energy) flux will point down the gradient.
Remember, gradient diffusion is a model for the flux (in my example, a heat flux): "what happens when I have a hot body and a cold body" kind of situation. In some circumstances, the above is not the case: the flux actually goes in the opposite direction. In that case, coming back to my example, you would have a cold water further heating up the hot brick. This model is, of course, unstable on its own, but you get such effects when you study things that are not really diffusion, like turbulence and try to model them in a diffusion-like manner. Enjoy, Hrv |
August 25, 2005, 05:16 |
ok thanks.
so how do we model non-gradient diffusion??? |
August 25, 2005, 05:59 |
In my views, the gradient is necessasry condtion for diffusion to occur. If there is no gradient, then there will not be any diffusion. So the question of non-gradient diffusion does not exist.
August 25, 2005, 07:25 |
Hrvoje's second example was not "non-gradient", it was counter-gradient. So, yes, a gradient is a necessary condition for diffusion, but the issue is the direction of the diffusion (and whether it is physically plausible).
August 25, 2005, 17:43 |
ok.
so how do we model counter gradient diffusion? and why might we get it? and should we model it...is it important??? |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Counter Gradient Diffusion | Paul | Main CFD Forum | 0 | August 21, 2005 17:40 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
How to compute gradient for non-orthogonal grids? | Paul Hsieh | Main CFD Forum | 3 | November 11, 2003 04:52 |
Counter gradient diffusion? | sheng | Main CFD Forum | 0 | July 23, 1999 07:34 |
