turbulent Prandtl number
Old   February 27, 2012, 06:41
Default turbulent Prandtl number
Nikolay Vinnichenko
nickvinn is on a distinguished road
Hello!
I'm trying to verify turbulence models for heat exchange in flat plate boundary layer (air, Re about 10^5). Spalart-Allmaras results are good with conventional constant turbulent Prandtl number 0.9. However, Baldwin-Lomax is better for Pr_turb=1.2. I tried Kays-Crawford variable Pr_turb formula and realized that it is somewhat paradoxical for me: if turbulent viscosity is small, as, I suppose, it is far from the wall, then Pe_turb=0 and Kays-Crawford model gives Pr_turb=2*0.85=1.7 (just as at the wall surface). Is it Ok far from the wall?
nickvinn is offline   Reply With Quote
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Turbulent Cylinder Strouhal Number Chetan Kadakia FLUENT 3 October 10, 2002 03:31
