Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Meshing around sharp trailing edge in CFX
Old   November 6, 2013, 18:27
Default Meshing around sharp trailing edge in CFX
Tom
ttu004 is on a distinguished road
Hi Guys
Could anyone tell me how to make the inflation around the sharp trailing edge of an airfoil without letting them skewed? (as shown in the figure below).
As my intention is to capture turbulent flow inside the near wall regions of an S814 airfoil, I have set the first cell height to 0.000014 m (y+ = 1) and the turbulent boundary layer thickness to 0.0116 m (using flat plate theory) by using the First layer thickness method. (maximum layers: 28, first layer height: 0.000014, growth rate: 1.2)
However, with this defined inflation control cells around the trailing edge (sharp tip) become highly skewed. And I believe that this is the reason that the computational results (lift/drag coefficients) are diverging from the experimental validation.
Thanks for any suggestions or advice
Tom
ttu004 is offline   Reply With Quote
Old   December 6, 2013, 17:46
Travis Carrigan
tcarrigan is on a distinguished road
It's extremely challenging to create a boundary layer resolved mesh via inflation that nicely wraps around the highly convex trailing edge corner. However, some tools offer the ability to wrap around convex corners by splaying off multiple normals as the inflation wraps around the corner (see image, normals highlighted in blue).
For airfoils with sharp trailing edges, traditionally you'll see people use c-grids. The other photo is a zoomed-in image of the trailing edge of an airfoil with a c-grid style extrusion.
- Travis
tcarrigan is offline   Reply With Quote
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge gmd ANSYS Meshing & Geometry 0 March 2, 2012 09:48
Meshing of a sharp edge orifice with a radius Moose1231 STAR-CD 3 December 6, 2011 15:32
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 15:19
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 13:23
Aerofoils/blades with rounded trailing edge. Sergei Chernyshenko Main CFD Forum 6 July 26, 2000 05:10
