Home > Forums > Special Topics > Mesh Generation & Pre-Processing
transition from prism to tetra
Old   June 11, 2014, 05:23
Default transition from prism to tetra
Jan Potac
potac is on a distinguished road
I am seeking for an advice related to prisms (inflation layer) and unstructured grid. It is recommended to keep certain growth factor between the last prism and tetra. This can be simply obtained specifying for example total thickness of the inflation layer, number of layers and growth factor. When defining uniform node sizing on a surface or an edge the smooth transition between the last prism cell and tetra remains. While applying some growth factor on the surface or edge results in larger steps between the last prism cell and tetra as the node spacing on the surface grows but the total inflation layer thickness remains. Should I keep the sizing uniform to avoid this or what would be the advice?
potac is offline   Reply With Quote
[ICEM] Fixing tetra Surface Orientations after prism generation siw ANSYS Meshing & Geometry 14 December 1, 2015 15:54
Mesh generation -purpose of tetra transition eishinsnsayshin Main CFD Forum 1 October 25, 2012 04:02
[ICEM] Tetra + prism turbine blade sarah4 ANSYS Meshing & Geometry 12 July 1, 2012 09:11
[ICEM] Tetra mesh quality before and after prism layer Chander ANSYS Meshing & Geometry 0 December 25, 2011 22:04
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
