Home > Forums > Software User Forums > Fidelity CFD
Hexahedral or Tetrahedral
Old   March 10, 2006, 03:46
Default Hexahedral or Tetrahedral
Maria Angelica
Hello! I am simulating an Inlet volute which has a blade ring at the end.
I am using ICEM and it is very easy to generate tretraheral meshes, but i have heard that using Hexahedral mesh would give better results.
I would really appreciate if somebody could explain me how more accurate the hexahedral is and why, so I can make more effort to the hexahedral mesh.
Thanks!!!
Old   March 22, 2006, 15:55
Default Re: Hexahedral or Tetrahedral
Roque Lopez
Dear Maria Angelica,
If you are planning to use NUMECA's software... I think you have no choice: mesh must be structured hexahedral (if using Fine/Turbo) or if you will use Fine/Hexa, then an unstructured hexahedral mesh is required. I think that NUMECA support team can help you better.
I used ICEM three years ago, I did the effort of meshing with structured hexahedral blocks, but the ICEM 'automatic' tool to write the mesh in NUMECA's software format didn't work. So, I had to mesh the whole thing again with IGG... which, in my opinion, is more easy to use than ICEM, specially when dealing with structured hexahedral blocks for complex geometries...
Good luck!
Roque.
PS. Do you speak spanish?
Old   April 4, 2006, 06:31
Remi
Hi Maria,
It is difficult to quantify how more accurate would be an hexahedral mesh. Comparisons between tetrahedral and hexahedral grids usually leads to following conclusions: - less cells are needed for an hexahedral mesh (that is certainly an advantage as you can then refine the mesh in some fluid zone for a same "budget") - convergence is better - prediction is said to be better (but this can be also a consequence of previous items).
Hope it helps Regards, Remi
Old   February 19, 2007, 00:10
rani
Hi all, Can anyone please share the code for generation of Hexahedral mesh or the source from where to get it!
Thanks Rani
Tetrahedral vs. Hexahedral Meshing for CFD Andy Bartels Main CFD Forum 16 September 20, 2019 10:06
Tetrahedral and hexahedral mesh based on FVM kuang Main CFD Forum 0 July 20, 2008 04:52
tetrahedral or hexahedral? rayy FLUENT 2 April 9, 2007 05:29
7 Node Hexahedral Cells Mark FLUENT 0 February 5, 2007 11:10
hexahedral vs. tetrahedral cells Christian Main CFD Forum 3 March 21, 2006 06:41
