Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Sample bugg with midPoint cell interpolationScheme
Old   November 12, 2010, 16:11
Default Sample bugg with midPoint cell interpolationScheme
nlc
nlc's Avatar
Nicolas Lussier Clément
nlc is on a distinguished road
I don't know if its a known bugg I just thought I should report it !!
using
interpolationScheme cell with midPoint for set will bugg with OpenFOAM 1.7.1 in a certain case !
Watt append hear is that the line I chose to sample on append to fit exactly with the faces of my structured mesh.
My 2D test case mesh is 1000m long and 100m high with 300 x 50 cells so at 100m I'm exactly on the face sheared by 30 and 31 column of cell !
the SampleDict is:
*--------------------------------*- C++ -*----------------------------------*\
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      sampleDict;
setFormat       raw;
surfaceFormat raw;
interpolationScheme cell;
fields
 U
 p
 epsilon
 k
sets
 x0
   type    midPoint;
   axis    z;
   start   ( 0 0 100);
   end     ( 0 0 0 );
 x100
   type    midPoint;
   axis    z;
   start   ( 100 0 100);
   end     ( 100 0 0 );
The error is :
Build  : 1.7.1-03e7e056c215
Exec   : sample -time 20000
Date   : Nov 12 2010
Time   : 15:40:56
Host   : ubi
PID    : 26371
Case   : /home/niko/OpenFOAM/niko-1.7.1/run/AEMN/case/ABL/ABLzMesh
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 20000
--> FOAM FATAL ERROR:
Found cell 14730 using face 60080. But cell does not contain point (100 1.27012e-14 98.1575)
    From function sampledSet::getCell(const label, const point&)
    in file sampledSet/sampledSet/sampledSet.C at line 75.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libOpenFOAM.so"
#2  Foam::sampledSet::getCell(int, Foam::Vector<float> const&) const in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#3  Foam::midPointSet::genSamples() in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#4  Foam::midPointSet::midPointSet(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#5  Foam::sampledSet::addwordConstructorToTable<Foam::midPointSet>::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#6  Foam::sampledSet::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#7  void Foam::PtrList<Foam::sampledSet>::read<Foam::sampledSet::iNew>(Foam::Istream&, Foam::sampledSet::iNew const&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#8  Foam::sampledSets::read(Foam::dictionary const&) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
#9  Foam::sampledSets::sampledSets(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccSPOpt/libsampling.so"
 at sample.C:0
#11
 in "/home/niko/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccSPOpt/sample"
#12  __libc_start_main in "/lib/libc.so.6"
#13
Abandon
If I run the same sampleDict with:
 x100
   type    midPoint;
   axis    z;
   start   ( 101 0 100);
   end     ( 101 0 0 );
no error and every thing is great !
Hope it help to get this wonderfully well programmed C++ library, OpenFOAM, even better.
As now I have no clue on how this bugg could be fixed.
Happy openfoaming to every one !
Nicolas Lussier
nlc is offline   Reply With Quote
Old   November 29, 2015, 06:49
Nicole Andrew
Nicole is on a distinguished road
Hi Nicolas,
I see your post is quite old, but I just came across the same thing, did you ever manage to figure this out?
I cannot see how you fixed it - it looks like you just used a different sample line location?
Nicole is offline   Reply With Quote
Old   November 30, 2015, 11:29
Default No modification of code !
nlc
nlc's Avatar
I did not look in to the code to try to fix this i just use an other location as you just said. It is possible o just use a tiny distence differnce ant this will work. In my experience this problem is only with midpoints. So unless you want to fix this isue in the C++ code I would advice you tdo like me and add 0.001 or an other small number to all location so the line you want data from crosses som faces cells.
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Running, Solving & CFD 0 October 27, 2009 08:47
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
