Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
How to handle the gcc412
Old   September 10, 2008, 23:32
Default hi, I am using OF1.4,it is ru
weihong yao
ivanyao is on a distinguished road
hi,
I am using OF1.4,it is run OK. But it can not compile applications, such as icoFoam.I domnload five files,they are OpenFOAM-1.4.General.GZ,OpenFOAM-1.4linuxGcc4DPOpt.gz,gcc-4.1.2.linux.tgz,j2sdk1 .4.2_05.linux.tgz,and paraview-2.4.4.linux.tgz.it is pass the foamInstallationTest. did I miss something?how can i do?would someone tell me the reason? it appear the error like that:
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/sstream:385: error: no type named 'off_type' in 'struct std::char_traits<wchar_t>'
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/sstream: In instantiation of 'std::basic_stringstream<wchar_t,>, std::allocator<wchar_t> >':
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/bits/sstream.tcc:265: instantiated from here
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/sstream:496: error: no type named 'int_type' in 'struct std::char_traits<wchar_t>'
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/sstream:498: error: no type named 'off_type' in 'struct std::char_traits<wchar_t>'
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:56: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:59: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:62: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:79: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:91: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/clock.H:94: error: 'time_t' does not name a type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/cpuTime.H:57: error: field 'startTime_' has incomplete type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/cpuTime.H:58: error: field 'lastTime_' has incomplete type
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/cpuTime.H:59: error: field 'newTime_' has incomplete type
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/streambuf: In member function 'typename _Traits::pos_type std::basic_streambuf<_chart,>::seekpos(typename _Traits::pos_type, std::_Ios_Openmode) [with _CharT = char, _Traits = std::char_traits<char>]':
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/streambuf:252: instantiated from 'typename _Traits::pos_type std::basic_streambuf<_chart,>::pubseekpos(typename _Traits::pos_type, std::_Ios_Openmode) [with _CharT = char, _Traits = std::char_traits<char>]'
/home/ivan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude/OStringStream.H:104: instantiated from here
/home/ivan/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../.. /../../include/c++/4.1.2/streambuf:599: error: no type named 'off_type' in 'struct std::char_traits<char>'
make: *** [Make/linuxGcc4DPOpt/fvMeshGeometry.o] error 1
ivanyao is offline   Reply With Quote
Old   March 28, 2015, 22:35
Karelke Yu
cfdopenfoam is on a distinguished road
Hi, weihong.
i think i have got the same errors with you.
may i konw how you solve the problem?
cfdopenfoam is offline   Reply With Quote
How to handle it ivanyao OpenFOAM Pre-Processing 6 August 24, 2008 21:27
Is UDF the only way to handle particle melting? marq FLUENT 3 February 23, 2008 01:48
Can CFX handle local hex refinement? JollyP CFX 2 October 31, 2006 09:00
Libstdcso6 cannot handle TLS data barryw OpenFOAM Installation 2 September 7, 2006 02:02
Can ALE handle air bubble breakups? Pei-Ying Hsieh Main CFD Forum 1 May 29, 2003 10:54
