Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Foam::pow() function not working with integer fraction
Old   September 10, 2009, 10:18
Default Foam::pow() function not working with integer fraction
Dominik Christ
dominik_christ is on a distinguished road
Hello everyone,
the following bug is present in both OF1.5 and OF1.6:
You would expect the following functions to return the same value
Info << pow(turbulence->epsilon(), (1./2.) );
Info << pow(turbulence->epsilon(), (1/2) );
Both compile without error or warning. However, the second line only returns the value 1 in all fields. The first line returns the square root of the epsilon field just as expected.
NB: This bug does not occur with plain integers, so
Info << pow(turbulence->epsilon(), 2. );
Info << pow(turbulence->epsilon(), 2 );
will give you the same (correct) result.
Regards,
Dominik Christ
P.S.: As this is such a fundamental function, I wonder why it passed unnoticed for so long ...
dominik_christ is offline   Reply With Quote
Old   September 10, 2009, 12:11
Mattijs Janssens
mattijs is on a distinguished road
The compiler will evaluate 1/2 as integer division. Hence it will be doing a pow(.., 0) which returns 1 as it should. Apart from this you could also use sqrt or sqr.
mattijs is offline   Reply With Quote
Old   September 10, 2009, 13:32
Dominik Christ
Oh, of course, that's the reason.
Thanks Mattijs for pointing that out to me!
Old   August 6, 2015, 12:19
Sandip Wadekar
wadekar is on a distinguished road
Hello
I am also struggling with same problem, but i want to do the power (1/3).
scalar rad = Foam::pow(Vol,1.0/3.0);
Vol is a scalar.
My main problem is that- when i using
then it gives right result without any problem, but its not running in parallel.
And, when i used
 scalar rad = Foam::pow(Vol,1/3);
then i am getting 1, but code is running in parallel.
wadekar is offline   Reply With Quote
bug, fraction, integer, pow
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
force function not working in OF 1.6 franzisko OpenFOAM 3 August 4, 2009 14:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
