Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OF-plus: Reconstruct problem for Qro scalarField with libs in controlDict
Old   September 19, 2016, 21:53
Default OF-plus: Reconstruct problem for Qro scalarField with libs in controlDict
Elisabet Mas de les Valls
elisabet is on a distinguished road
Dear all,
I'm using version OF-plus from 13 July 2016 (plus-5d9038294daa). I need to add a new radiation library to controlDict file. But even if I add the original libradiationModels.so this problem appears:
When the volScalarField Qr is reconstructed, the scalarField Qro is filled with non-zero values despite its original value is 'uniform 0'.
Till now I have observed that:
  • If no library is included in controlDict file, this error does not appear.
  • If I add the library but without the NamedEnum definition (and proper .C modifications) in file submodels/boundaryRadiationProperties/boundaryRadiationPropertiesPatch.C, this problem does not appear.
  • If I use OF-dev this problem does not appear.
I attached a case to reproduce the error. The steps to reproduce it are:
  1. extract files from possibleBugReconstruct.tar.gz
  2. ./Allrun-parallel
  3. reconstructPar -allRegions -time 10
  4. vim 10/left/Qr (and check for Qro field)
Any hint would be appreciated!
Elisabet
elisabet is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
Reconstruct problem with IHFOAM Antoniorp OpenFOAM 1 May 18, 2015 16:09
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
