Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in blockMesh
Old   March 4, 2009, 08:47
Default Hi, The problem is describ
Andreas Feymark
feymark is on a distinguished road
The problem is described here: http://www.cfd-online.com/OpenFOAM_D...tml?1236010571 .
I traced it down to the "importance factors", computed in blockPoints.C, which gets too big. My solution to this was to, before the "importance factors" are used, add this piece of code:
scalar impxtot = impx1 + impx2 + impx3 + impx4;
impx1 /= impxtot;
impx2 /= impxtot;
impx3 /= impxtot;
impx4 /= impxtot;
scalar impytot = impy1 + impy2 + impy3 + impy4;
impy1 /= impytot;
impy2 /= impytot;
impy3 /= impytot;
impy4 /= impytot;
scalar impztot = impz1 + impz2 + impz3 + impz4;
impz1 /= impztot;
impz2 /= impztot;
impz3 /= impztot;
impz4 /= impztot;
This works well on the cases I have looked at. Is there a better solution?
/Andreas
feymark is offline   Reply With Quote
Old   March 4, 2009, 09:09
Default Heya, This is a long-standi
Hrvoje Jasak
Heya,
This is a long-standing bug (mine) and the code simply looked too complex to look at 15 years after it was written.
What you are saying is that the sum of weighting factors is not zero, right? Can you tel me by how much the factors are out and if you can tell why the sum of weights is not equal to one.
Please let me know, this has bothered me for a long time.
Hrv
Hrvoje Jasak
Old   March 4, 2009, 11:12
Default I pretty sure the error lies w
Andreas Feymark
I pretty sure the error lies within the method. I have confirmed by doing calculations by hand that the code does what it's suppose to do. Using the blockMeshDict I posted in the other thread I get values of impx = 0.725, impx2 = 0.375, impx3 = impx4 = 0 for i = 1, j = 1, k = 0.
/Andreas
Old   March 6, 2009, 04:54
Default I pushed a change to blockPoin
Mattijs Janssens
mattijs is on a distinguished road
I pushed a change to blockPoints.C to 1.5.x. Seems to fix the case from http://www.cfd-online.com/cgi-bin/Op...2873#POST32873
mattijs is offline   Reply With Quote
Old   March 23, 2009, 21:49
Default blockMesh problem in interDyMFoam
musaddeque hossein
musahossein is on a distinguished road
In the 2D tank sloshing problem, I am modeling the tank as rectangular not the chamfered one in the tutorial. When I run blockMesh, it crashes. My question is blockMesh in interDyMFoam configured to run only the chamfered shape in the tutorial or can it accept any shape?
Musa
musahossein is offline   Reply With Quote
Old   March 24, 2009, 04:20
Mattijs Janssens
It can accept any (multiblock structured) shape.
Old   March 24, 2009, 14:09
Default problem with Block mesh in the 2D tank sloshing tutorial
musaddeque hossein
My input is included below. I have followed the input format in the 2d sloshing tank:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
( -0.5 -0.5 0.05) // 0
( 0.5 -0.5 0.05) // 1
( 0.5 0.5 0.05) // 2
( -0.5 0.5 0.05) // 3
( -0.5 0.5 -0.05) // 4
( -0.5 -0.5 -0.05) // 5
( 0.5 -0.5 -0.05) // 6
( 0.5 0.5 -0.05) // 7
blocks
hex (0 1 2 3 5 6 7 4)
(10 10 1)
simpleGrading (1 1 1)
patches
patch walls
(0 1 6 5)
(1 2 7 6)
(2 3 4 7)
(3 0 5 4)
empty front
(0 1 2 3)
empty back
(5 4 7 6)
But when I run blockMesh, I get the following warnings. I have no clue as to why. The warning also states that I might have the surfaces inside out. However, I have followed the numbering scheme where the numbers run counterclockwise when looking at the surface from inside the block.
musa@linux-ip9p:~/OpenFOAM/musa-1.5/run/tutorials/interDyMFoam/sloshingTank2Dtest> blockMesh
Exec : blockMesh
Date : Mar 24 2009
Time : 16:01:23
Host : linux-ip9p
PID : 4494
Case : /home/musa/OpenFOAM/musa-1.5/run/tutorials/interDyMFoam/sloshingTank2Dtest
nProcs : 1
Create time
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
There are no non-linear edges
Creating blocks
Creating patches
Creating block mesh topology
--> FOAM Warning :
From function cellModel::mag(const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.C at line 134
zero or negative pyramid volume: -0.0166667 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -0.0166667 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -0.0166667 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -0.0166667 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -0.0166667 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -0.0166667 for face 5
--> FOAM Warning :
From function blockMesh::createTopology(IOdictionary&)
in file createTopology.C at line 412
negative volume block : 0, probably defined inside-out
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points
Creating cells
Creating patches
Creating mesh from block mesh
There are no merge patch pairs edges
Writing polyMesh
end
I apologise for the etremely long post. I hope the brevity of the problem will make it easier to review.
Musa
Old   March 24, 2009, 14:45
Mattijs Janssens
Your point ordering is wrong. See e.g. Userguide U-21.
Old   March 24, 2009, 22:11
Default blockmesh issues in interDyMFoam
musaddeque hossein
Many thanks for your response.
The point numbering you are refering to on U-21 puts the origin at a corner. The origin in the sloshing tank is at the COG of the tank. I looked at both. In U-21, the number scheme goes counter clockwise on each face with the normal on the outer surface of each face. In the 2d tank sloshing tutorial, the numbering shceme (as well as the dam break problem), the surface normal points into the tank. So the numbering schemes appear to be opposite. I will look at this further..
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 19:54
[blockMesh] BlockMesh problem pratap OpenFOAM Meshing & Mesh Conversion 21 February 16, 2009 06:32
[blockMesh] BlockMesh checks msrinath80 OpenFOAM Meshing & Mesh Conversion 1 April 16, 2007 06:47
[blockMesh] BC with blockMesh ville OpenFOAM Meshing & Mesh Conversion 1 December 4, 2006 05:11
BlockMesh trouble r2d2 OpenFOAM Pre-Processing 2 January 16, 2006 09:51
