Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Minor bug in cellQualityC
Old   February 13, 2009, 06:15
Default Dear all, I observed for 2
Frank Bos
lr103476 is on a distinguished road
Dear all,
I observed for 2D cases that the nonOrthogonality() and faceNonOrthogonality() functions in cellQuality can cause a 'floating points exceptions'. This occurs in the calculation of cosDDotS = Foam::acos((d & s)/(mag(d)*magS + VSMALL)), apparently VSMALL is too small and indeed, when I change this in SMALL, everything works fine again.
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   February 13, 2009, 06:45
Default The problem is that for very s
henry is on a distinguished road
The problem is that for very small geometries you will find that SMALL is too big. I guess we will need to make VSMALL a bit bigger, could you find out how much bigger VSMALL has to be for your case?
Thanks
H
henry is offline   Reply With Quote
Old   February 13, 2009, 07:12
Default I already did that. in my case
Frank Bos
I already did that. in my case VSMALL need to be 1e-16, so almost SMALL.
The case is not very small, just a moving 2D block on a 2D domain which is 25 squared. Overall domain bounding box (-12.5 -12.5 -0.1) (12.5 12.5 0.1).
Frank
Frank Bos
Old   February 13, 2009, 07:24
Default Is the problem in acos getting
Mattijs Janssens
mattijs is on a distinguished road
Is the problem in acos getting a number >1 or in the division?
Could you try something like
Foam::acos(min(1.0, (d & s)/(mag(d)*magS + VSMALL)))
mattijs is offline   Reply With Quote
Old   February 13, 2009, 07:28
Default Just my two cents: the point i
Assistant Moderator
Bernhard Gschaider
Just my two cents: the point in that VSMALL constant is to avoid division by zero, and get zero if (d&s) is zero, is it? How about replacing it with max(VSMALL,SMALL*max(mag(d),mag(s))) or something similar that would correlate it to the local sizes. But I havn't looked at the full source so I may be talking nonsense
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Default Thanks Mattijs, this solved th
Frank Bos
Thanks Mattijs, this solved the problem.
Frank
Frank Bos
Minor buoyancy problem in Phoen2007 patti Phoenics 3 December 1, 2007 18:43
Minor bug in CrankNicholsonDdtScheme henry OpenFOAM Bugs 5 May 22, 2007 11:52
Minor compilation problem with Gcc42 schmidt_d OpenFOAM Bugs 1 May 9, 2007 13:11
Minor loss coefficients Nick Main CFD Forum 3 October 7, 2004 11:28
minor loss k values clifford bradford Main CFD Forum 1 August 2, 2000 16:58
