October 15, 2008, 02:23 |
I think you should file it as
Mark Olesen
Rep Power: 40 |
I think you should file it as a bug.
But IMO the solution would be to change Foam::probes::sampleAndWrite to just use spaces. ie, probeStream << vField.time().value(); forAll(values, probeI) { probeStream << ' ' << values[probeI]; } probeStream << endnl; This would give properly separated fields, without the hassles of an sprintf() format - eg, someone is silly and specifies "%s" |
October 15, 2008, 03:55 |
For now I have added a space t
Rep Power: 22 |
For now I have added a space to the current column formatting to "protect" the numbers should they fill the field width allocated and will push this change into our git repository shortly.
We will also review the formatting options and consider more flexible specifications. H |
October 15, 2008, 15:14 |
What if i want to calcu
Vishal Jambhekar
Rep Power: 17 |
What if i want to calculate Grad phi and grad P at wall for supersonic flow.... Do u know any utelities for that... Thanks Vishal
Cheers, Vishal Jambhekar... "Simulate the way ahead......!!!" |
October 15, 2008, 15:51 |
on the other hand, sprintf() f
Maxim Loginov
Rep Power: 17 |
on the other hand, sprintf() format allow more flexibility: vectors can be written as
(0.0 0.1 0.2) # as it is now or (0.0, 0.1, 0.2) # might be preferable for postprocessing |
Use gnuplot to produce residual plots in run time? | chenzhi | Main CFD Forum | 2 | September 8, 2008 20:58 |
grid check failed due to the merged zones | biksham | FLUENT | 0 | February 20, 2008 22:31 |
gambit: how to produce hanging notes | Ralf Schmidt | FLUENT | 4 | July 15, 2007 16:52 |
mesh generator, that can produce hanging notes? | Ralf Schmidt | Main CFD Forum | 2 | July 14, 2007 01:57 |
How to produce the geometry file for Es-ice | lizhihua | Siemens | 0 | December 4, 2006 06:49 |
