Proposal for an extension for the timeoptions of Utilities |
March 14, 2008, 09:37 |
Hi!
One problem I encounter
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
One problem I encounter frequently is that the options -time/-latestTime only let me specify either all or one time-step. This is sometimes quite inconvenient (for instance a reconstructPar of a case of which one half has already been reconstructed only gives me the possibility to reconstruct the first half of the timesteps anew or reconstruct one time-step at a time; for utilities like sample that remove old data when being called this is also quite annoying if you want to sample only two time-steps out of 100) I thought it would be nice to have an option -times that gives the possibility to specifie multiple times: -times 100,101.5,105 or specify a range -times 100_110 or an open range -times 100_ or only ever 2 seconds -times 100_2_110 or only every 5th time-step in the range -times 100:5:110 or a combination -times 0,50,100_ What do you think? Actually I did an example implementation. It's a bit clumsy because I tried not to modify the application-sources and did not want to modify kernel-classes, but it works alright and as far as I can tell it does not break compatibility with the old options. I'll append it as a patch. timesOption.patch
March 14, 2008, 09:59 |
Yes I totally agree and a more
Rep Power: 22 |
Yes I totally agree and a more general time and time-range selection scheme has already been implemented which will be in included in the next release.
Henry |
August 20, 2008, 09:23 |
Excuse me for being a bit slow
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Excuse me for being a bit slow-witted. That would be what the point "Extended time command line options." in the 1.5 Release-Notes is referring to, wouldn't it? My problem is, that I can't see how to select such a thing with the stock utilities (reconstructPar/checkMesh), I didn't find any reference in the documentation and in the source ($FOAM_SRC/OpenFOAM/include/addTime*.H etc would be the place to look at, wouldn't it?).
Did I miss something or is it possible that that feature got stuck in git somewhere and simply isn't in the release? Bernhard
August 21, 2008, 12:09 |
Hi Bernhard,
I'm not at my
Mark Olesen
Rep Power: 40 |
Hi Bernhard,
I'm not at my desk at the moment, but take a look at the timeSelector class (I think), it is used in some of the utils like Mach etc. |
August 25, 2008, 16:28 |
Hi Mark!
Thanks. Didn't see
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Mark!
Thanks. Didn't see that. As a repentance I wrote this little page on the Wiki for all those who don't want to look it up in the source: http://openfoamwiki.net/index.php/Ti...ection_Options Bernhard
August 26, 2008, 19:13 |
Thanks for those tips Bernhard
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Thanks for those tips Bernhard :-)
Proposal for a modification of the initscripts to make switching versions easier | gschaider | OpenFOAM Bugs | 2 | December 21, 2007 14:10 |
New Utilities | coops | OpenFOAM Post-Processing | 1 | July 4, 2007 04:21 |
find a Phd and a master degree proposal | Sabbagh | Main CFD Forum | 1 | January 7, 2007 00:49 |
Proposal w.r.t. Meshing & Mesh Generation articles | jasond | CFD-Wiki | 3 | October 18, 2006 19:03 |
Reference Format Guidelines - a Proposal | Jonas Larsson | CFD-Wiki | 4 | September 16, 2005 04:54 |
