Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Canbt compile libso autoMesh OF15
Old   July 15, 2008, 07:15
Default Hi, I am trying to compile
Andrew King
andersking is on a distinguished road
I am trying to compile 1.5 from the source, all is fine except for lib autoMesh.
The error I get is
+ wmake libso autoMesh
SOURCE=autoHexMesh/autoHexMeshDriver/autoRefineDriver.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/decompositionAgglomeration/decompositio nMethods/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/dynamicMesh/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/edgeMesh/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/triSurface/lnInclude -IlnInclude -I. -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/anders/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/autoRefineDriver.o
/home/anders/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/PtrList.C: In copy constructor 'Foam::PtrList<t>::PtrList(const Foam::PtrList<t>&) [with T = Foam::featureEdgeMesh]':
autoHexMesh/autoHexMeshDriver/autoRefineDriver.C:260: instantiated from here
/home/anders/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/PtrList.C:56: error: invalid conversion from 'Foam::IOobject*' to 'Foam::featureEdgeMesh*'
make: *** [Make/linuxGccDPOpt/autoRefineDriver.o] Error 1
I am compiling with gcc-4.2.3 (ubuntu system compiler)
I will try to use the binary package for now.
Good work, though, looking forward to testing this out.
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   July 15, 2008, 07:35
Default I've recompiled everything fro
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I've recompiled everything from source (except the docs), using gcc-4.3.1 and the top-level OpenFOAM-1.5/Allwmake.
Everything went fine, so it looks like a gcc issue to me. I'm using SuSE 10.3 (64-bit) with the ThirdParty gcc.
The new bin/buildParaView3.3-cvs script also worked fine, but I fortunately already had the correct Qt installed. This can sometimes be a really annoying issue with paraview. If you've already compile paraview from cvs sources, you might need to do a fresh cvs checkout - there are sometimes leftover cmake files that confuse newer builds.
olesen is offline   Reply With Quote
Old   July 18, 2008, 08:06
Default Hi Andrew! I think the prob
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Hi Andrew!
I think the problem you are experiencing is a problem with old gcc-versions. I did a small workaround for that in order to get it to compile with gcc-4.0.1 on my Mac. Have a look at the first patch-file in the thread http://www.cfd-online.com/OpenFOAM_D...tml?1216382195 and edit autoRefineDriver.C (don't apply the whole patch unless you feel lucky)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   July 20, 2008, 09:37
Default Thank you Bernhard. Does the
Michael Roth
roth is on a distinguished road
Thank you Bernhard. Does the trick.
Note the hand-patched source is below:
autoRefineDriver.C.gz
Michael
roth is offline   Reply With Quote
Old   July 20, 2008, 22:54
Default Hi Bernhard, Thanks for th
Andrew King
Hi Bernhard,
Thanks for that. I'll give it a try at some point - In the end I relented and installed all the Thirdparty binaries.
Cheers
Andrew
Dr Andrew King
Curtin University
Old   May 16, 2009, 12:31
Default wmake libso autoMesh fails to compile
Dominic Spreitz
DSpreitz is on a distinguished road
As I wanted to upgrade from OF1.5 to 1.5-dev I did the svn checkout and so forth, updated my .bashrc and tried compiling 1.5-dev.
As I already suspected some errors to pop up, I decided to compile stuff seperately and not to use the top level Allwmake script. So I started in ~/OpenFOAM/OpenFOAM-1.5-dev/src$ by running the Allwmake script there.
However, once it tries to compile autoMesh it fails, for reasons beyond my understanding. Can somebody help me with this issue, please?
Here is some information about my system and the actual log off wmake libso autoMesh:
user@pelican:~/OpenFOAM/OpenFOAM-1.5-dev/src/autoMesh$ which gcc
/home/user/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
user@pelican:~/OpenFOAM/OpenFOAM-1.5-dev/src/autoMesh$ gcc -v
Using built-in specs.
Target: i686-pc-linux-gnu
Configured with: ../configure --prefix=/usr/tmp/gcc-4.3.1 --exec-prefix=/usr/tmp/gcc-4.3.1 --enable-languages=c,c++ --enable-shared --enable-__cxa_atexit --disable-checking --with-system-zlib
Thread model: posix
gcc version 4.3.1 (GCC)
user@pelican:~/OpenFOAM/OpenFOAM-1.5-dev/src/autoMesh$ which flex
/usr/bin/flex
user@pelican:~/OpenFOAM/OpenFOAM-1.5-dev/src/autoMesh$ which flex++
/usr/bin/flex++
user@pelican:~/OpenFOAM/OpenFOAM-1.5-dev/src/autoMesh$ head -n20 log_compile_autoMesh
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/decompositionAgglomeration/decompositionMethods/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/dynamicMesh/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/lagrangian/basic/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/meshTools/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/edgeMesh/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/triSurface/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude   -fPIC -pthread Make/linuxGccDPOpt/autoLayerDriver.o Make/linuxGccDPOpt/autoLayerDriverShrink.o Make/linuxGccDPOpt/autoSnapDriver.o Make/linuxGccDPOpt/autoRefineDriver.o Make/linuxGccDPOpt/autoHexMeshDriver.o Make/linuxGccDPOpt/layerParameters.o Make/linuxGccDPOpt/refinementParameters.o Make/linuxGccDPOpt/snapParameters.o Make/linuxGccDPOpt/pointData.o Make/linuxGccDPOpt/meshRefinementBaffles.o Make/linuxGccDPOpt/meshRefinement.o Make/linuxGccDPOpt/meshRefinementMerge.o Make/linuxGccDPOpt/meshRefinementProblemCells.o Make/linuxGccDPOpt/meshRefinementRefine.o Make/linuxGccDPOpt/refinementSurfaces.o Make/linuxGccDPOpt/shellSurfaces.o Make/linuxGccDPOpt/trackedParticle.o Make/linuxGccDPOpt/trackedParticleCloud.o -L/home/user/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt \
          -lOpenFOAM -ldl   -lm -o OpenFOAM.out
/usr/lib/crt1.o: In function `_start':
/build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:115: undefined reference to `main'
Make/linuxGccDPOpt/autoLayerDriver.o: In function `Foam::autoLayerDriver::getLayerCellsFaces(Foam::polyMesh const&, Foam::addPatchCellLayer const&, Foam::List<bool>&, Foam::List<bool>&)':
autoLayerDriver.C:(.text+0x53b): undefined reference to `Foam::addPatchCellLayer::addedCells(Foam::polyMesh const&, Foam::List<Foam::List<int> > const&)'
Make/linuxGccDPOpt/autoLayerDriver.o: In function `Foam::autoLayerDriver::doRestorePoints(Foam::removePoints&, Foam::List<int> const&)':
autoLayerDriver.C:(.text+0xaba): undefined reference to `Foam::directTopoChange::directTopoChange(Foam::polyMesh const&, bool)'
autoLayerDriver.C:(.text+0xb02): undefined reference to `Foam::removePoints::getUnrefimentSet(Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&) const'
autoLayerDriver.C:(.text+0xb2b): undefined reference to `Foam::removePoints::setUnrefinement(Foam::List<int> const&, Foam::List<int> const&, Foam::directTopoChange&)'
autoLayerDriver.C:(.text+0xb64): undefined reference to `Foam::directTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool)'
autoLayerDriver.C:(.text+0xc15): undefined reference to `Foam::removePoints::updateMesh(Foam::mapPolyMesh const&)'
Make/linuxGccDPOpt/autoLayerDriver.o: In function `Foam::autoLayerDriver::doRemovePoints(Foam::removePoints&, Foam::List<bool> const&)':
autoLayerDriver.C:(.text+0xf2a): undefined reference to `Foam::directTopoChange::directTopoChange(Foam::polyMesh const&, bool)'
autoLayerDriver.C:(.text+0xf46): undefined reference to `Foam::removePoints::setRefinement(Foam::List<bool> const&, Foam::directTopoChange&)'
autoLayerDriver.C:(.text+0xf7f): undefined reference to `Foam::directTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool)'
autoLayerDriver.C:(.text+0x102d): undefined reference to `Foam::removePoints::updateMesh(Foam::mapPolyMesh const&)'
Make/linuxGccDPOpt/autoLayerDriver.o: In function `Foam::autoLayerDriver::checkAndUnmark(Foam::addPatchCellLayer const&, Foam::dictionary const&, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::fvMesh const&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<Foam::autoLayerDriver::extrudeMode>&)':
autoLayerDriver.C:(.text+0x1364): undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)'
autoLayerDriver.C:(.text+0x139d): undefined reference to `Foam::motionSmoother::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&)'
Regards,
Dominic
DSpreitz is offline   Reply With Quote
Old   May 17, 2009, 05:02
henry is on a distinguished road
Have you tried upgrading to 1.5.x from the OpenCFD git repository?
henry is offline   Reply With Quote
Old   May 17, 2009, 09:49
Henrik Rusche
henrik is on a distinguished road
Dear Dominic,
I do not think it's wise to start the compilation somewhere in the middle for any release of OpenFOAM. Usually
cd $FOAM_SRC/..
rmoall
./Allwmake |& tee Allwmake.log
does most of the jobs and you can start working from the errors. So write a log and inspect.
@your particular problem: I noticed that the gcc command has "-o OpenFOAM.out" in it.
This usually happens when you use "wmake" instead of "wmake libso" on a library. I understand that you use the src/Allwmake, which says "wmake libso autoMesh". How comes - I do not know ... Please try
cd $FOAM_SRC/autoMesh
wmake libso
and let us know whether it works.
Henrik
henrik is offline   Reply With Quote
Old   May 18, 2009, 01:20
Dominic Spreitz
Hey Henrik,
Thanks for your reply. You're right, in stating, that:
Originally Posted by henrik View Post
Dear Dominic,
cd $FOAM_SRC/..
rmoall
Starting all over and beginning with the top level Allwmake solved my problems. I got the idea of compiling stuff seperately from the wiki page, which was writen for OF 1.4.1-dev.
So to conclude:
- This is not a bug, I posted in the wrong forum, sorry.
- Do NOT try to appy the instructions given in http://openfoamwiki.net/index.php/Ho...M_the_easy_way to compile OF 1.5-dev
- Use the top level Allwmake to compile
Thanks to Henry for getting me back on track.
Regards
Dominic
Old   May 1, 2013, 07:29
fatemeh sadeghpour
fatemeh.sadeghpour is on a distinguished road
Hi gschaider
gschaider I know it is too late and i am sorry for bothering you.
I has uses your Idea in compling gcc-4.3.1 to compile openfoam-1.5-dev.
but after a week, I do not have any success.in configure gcc-4.3.1(after installing mpfr-2.3.2):
igure --prefix=$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64 --exec-prefix=$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64 --enable-languages=c,c++ --enable-shared --disable-multilib --with-mpfr=$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/mpfr-2.3.2/but it has a problem and i do not know what to do:
checking LIBRARY_PATH variable... contains current directory
configure: error:
*** LIBRARY_PATH shouldn't contain the current directory when
*** building gcc
. Please change the environment variable
*** and run configure again.
make[2]: *** [configure-stage1-gcc] Error 1
please help me .
thank you.
fatemeh.sadeghpour is offline   Reply With Quote
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 12:22
OF15 libccmio and thus ccm26ToFoam do not compile henry OpenFOAM Bugs 29 July 21, 2011 17:23
Wmake libso roberthino OpenFOAM Installation 1 October 1, 2007 12:00
Canbt compile MRF Testcase deepblue17 OpenFOAM Installation 4 May 11, 2007 22:43
when i use the star-cd automesh,i meet the erro dpshaka Siemens 0 October 27, 2005 04:09
