Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
TwoPhaseEulerFOAM application
Old   November 16, 2006, 07:27
Default Description: The application
Rasmus Hemph
hemph is on a distinguished road
Description:
The application gives erroneous solution for the Ua-field when the particle-particle force is included (g0 > 0). If settling particles are simulated, the velocity of the particles does not approach zero as they reach the bottom of the domain.
Solution. The ppMagf-term in alphaEqn.H: should be divided by alphaf on row 26.
Old:
ppMagf = g0*rUaAf*min(exp(preAlphaExp*(alphaf - alphaMax)), expMax);
New:
ppMagf = 1.0/(rhoa*max(alphaf,SMALL))*g0*rUaAf*min(exp(preAlpha Exp*(alphaf - alphaMax)), expMax);
Also row 32 in alphaEqn.H needs to be changed.
Old:
alphaEqn -= fvm::laplacian(ppMagf, alpha);
New:
alphaEqn -= fvm::laplacian(alphaf*ppMagf, alpha);
Solver/Application:
twoPhaseEulerFoam
Source file:
alphaEqn.H
Testcase:
twoPhaseEulerFoamPack1D.tar.gz
Platform:
All
Version:
All
Notes:
The dimension of g0 is in Pascal in most references. In twoPhaseEulerFoam the dimensions of g0 is Pa/(kg/m3). To aid comparison between models, the ppMagf term should be divided by rho, as
with a corresonding change to the dimensions of g0 in constant/ppProperties
hemph is offline   Reply With Quote
TwoPhaseEulerFOAM application hemph OpenFOAM Bugs 35 November 6, 2011 01:06
TwoPhaseEulerFoam sara OpenFOAM Running, Solving & CFD 2 November 6, 2008 19:26
Bug in twoPhaseEulerFoam alberto OpenFOAM Bugs 2 May 20, 2008 21:25
TwoPhaseEulerFoam Bug alondono OpenFOAM Bugs 1 February 19, 2008 20:01
TwoPhaseEulerFoam newbee OpenFOAM 0 March 27, 2006 08:41
