Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OpenFOAM 1.5.x.git
Old   March 19, 2009, 08:23
Default setDeltaT
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Im running 1.5.x.git version.
dont know if this counts as a bug, but it produces a sigFpe error.
I'm running engineCompRatio and when I reach TDC it crashes.
I traced the crash to the setDeltaT-line, when t1=0
while(mag(ca-ca1) > eps)
    ca = runTime.theta();
    scalar t1 = runTime.userTimeToTime(ca1-ca);
    runTime.setDeltaT(t1);
    runTime++;
    Info << "CA = " << runTime.theta() << endl;
    mesh.move();
Its easily fixed by the modification below.
But should there be some sort of warning/fix in setDeltaT when one tries to set the timestep to 0.
    if (mag(ca-ca1) > eps)
        runTime++;
        mesh.move();
N
niklas is offline   Reply With Quote
Old   March 22, 2009, 17:46
henry is on a distinguished road
Is it possible for the first loop:
if (mag(ca - ca0) > eps)
while(mag(ca - ca0) > eps)
scalar t0 = runTime.userTimeToTime(ca0 - ca);
runTime.setDeltaT(t0);
runTime++;
Info << "CA = " << ca << endl;
mesh.move();
to suffer from the same problem? Also wouldn't it be better to reorganize the loops so that the test is only required once?
H
henry is offline   Reply With Quote
Old   March 23, 2009, 04:46
niklas's Avatar
Niklas Nordin
Sorry for the bad naming of the topic, I tried to edit it afterwards, but that wasnt possible...
runTime++;
mesh.move();
Yes, it is. I just havent seen this yet since I always start at BDC so the
criteria at the entry of the while statement is always false.
I just realized you dont have to do anything really,
just replace the ca-caX from the while (..) check and
use runTime.theta()-caX, then the if's can be removed.
N
Old   March 23, 2009, 10:35
Thanks for the fix, I have pushed it into 1.5.x.
H
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
[OpenFOAM.com] OpenFOAM SteliosNTUA OpenFOAM Installation 4 March 8, 2007 03:15
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
