April 29, 2009, 08:51 |
Swap usage on parallel run
SSD
Rep Power: 17 |
Hello
I am running the cases on parallel processors with metis domain decomposition. While the run starts, process start eating up RAM. But before the RAM gets exhausted, process starts using system SWAP space. And soon, SWAP usage reaches 100%. Is there any specific command which is limiting the RAM usage in OpenFoam run. I was facing this issue with 5 million grid size on 128 processor. Please guide why this is happening. Thanks and regards Sagar |
April 30, 2009, 04:42 |
Mattijs Janssens
Rep Power: 26 |
You have posted on the bugs section. Please post generic questions on the relevant other forums, i.e. cfd/running unless you suspect there is a bug.
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
MPICH Parallel Run Error on the Windows Server2003 | Saturn | CFX | 3 | August 29, 2006 08:42 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
