Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Postprocessing and uniformDensityHydrostaticPressure in v1.6
Old   July 28, 2009, 11:27
Default Postprocessing and uniformDensityHydrostaticPressure in v1.6
Julien Schaguene
Schag is on a distinguished road
I was glad to see the uniformDensityHydrostaticPressure in OpenFoam 1.6 and try to use it in order to see if this was what I was looking for.
The simulation works, I think, but when using paraFoam or foamToVTK, the following error message appears:
Time: 0
request for uniformDimensionedVectorField g from objectRegistry region0 failed
available objects of type uniformDimensionedVectorField are 0()
From function objectRegistry::lookupObject<Type>(const word&) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
I know a new version cannot be perfect, but if you have any solution/suggestion,
regards,
Julien
Schag is offline   Reply With Quote
Old   July 28, 2009, 12:47
Mattijs Janssens
mattijs is on a distinguished road
It expects the gravity 'g' to be loaded in the objectRegistry which is true for the simulation. As a work-around change (with an editor) the type of the bc into fixedValue so you can postprocess it.
mattijs is offline   Reply With Quote
Old   July 28, 2009, 13:41
Mattijs Janssens
Note: you should only get this problem because you do not have a 'value' entry so the boundary condition needs to do an evaluation.
Postprocessing in 3d - Creating part of a surface shankara.2 FLUENT 0 July 13, 2009 17:33
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
Postprocessing in 2D - specific area Anthony Wachs FLUENT 3 July 6, 2001 10:59
postprocessing bas rijkse FLUENT 0 July 5, 2001 08:30
Win NT, pre and postprocessing with large problems Dirk FLUENT 1 February 7, 2001 14:50
