Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
1.6.x -> snappyHexMesh in parallel fails ...
Old   July 31, 2009, 23:18
Default 1.6.x -> snappyHexMesh in parallel fails ...
Pierre-Olivier Dallaire
podallaire is on a distinguished road
I'm experiencing some difficulties when trying to run snappyHexMesh with
mpirun and 2 cpus / I have tried the same case under 2 different machines
and have the same error. Note that the same case was working well under
1.5.x. Here is the message :
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Read mesh in = 0.11 s
[1]
[1]
[1] Cannot find file "" in directory "constant/triSurface"
[1]
[1] From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
[1] in file db/Time/findInstance.C at line 148.Overall mesh bounding box : (-22.5 -40 -0.0001) (22.5 40 18)
[1]
FOAM parallel run exiting
[1] Relative tolerance : 1e-08
Absolute matching distance : 9.3536109e-07
[0]
[0]
[0] Cannot find file "" in directory "constant/triSurface"
[0]
[0] From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
[0] in file db/Time/findInstance.C at line 148.
[0]
[0]
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
Best regards,
PO
podallaire is offline   Reply With Quote
Old   August 1, 2009, 05:07
Mattijs Janssens
mattijs is on a distinguished road
As a workaround softlink or copy the constant/triSurface directory to the processor directories for now.
mattijs is offline   Reply With Quote
Old   August 1, 2009, 08:43
ok, yes, the softlink works
Old   August 1, 2009, 09:56
another strange thing is that I cannot use decomposePar on a blockMesh which
was refined with refineMesh / I never had this problem before.
Regards,
PO
Old   August 1, 2009, 18:49
sorry not to start a new thread for this / since I'm discussing meshing "challenges", I guess it's appropriate to re-use this thread ...
I believe that db/Time/timeSelector.C is causing problems whith checkMesh, it does not find the "constant" folder when no time steps are available.
Old   August 3, 2009, 03:53
Mattijs Janssens
Just create a dummy time directory; mkdir 0.
Old   August 3, 2009, 08:22
Yes, that is what I tried yesterday.
Also, it appears that my problems when it comes to decompose a refined
mesh are caused by the "-overwrite" flag; I found out that not using this flag
and moving the new mesh in constant/polyMesh does not cause problems.
I also have issues with the same flag when using snappyHexMesh, that is why,
for now, I will not use it and will always move the polyMesh folder.
PO
Old   August 4, 2009, 00:42
Default Assign flow fields to decomposed mesh?
Cem Albukrek
albcem is on a distinguished road
Relevant to "snappyhexmesh in parallel" topic stream, is there a way to assign the flow fields to the decomposed mesh that was built using snappyhexmesh in parallel?
Essentially, I am working with a 32 bit machine and I am pushing the OS memory limit on the size of mesh by using snappyhexmesh in parallel. After the decomposed mesh is built, I need to assign the flow fields to it, but obviously I am not able to first reconstruct the decomposed mesh.
Any ideas on how I can tackle the issue, without having to buy a 64bit machine?
Thanks.
Cem
albcem is offline   Reply With Quote
Old   August 4, 2009, 04:17
Mattijs Janssens
Regarding the -overwrite : remove the polyMesh/pointLevel, cellLevel and refinementHistory files. They should be consistent with the snappyHexMesh generated mesh so if you've regenerated a blockMesh they are no longer valid. I'll push a check into 1.6.x so at least you'll get an error message.
Old   August 4, 2009, 04:23
Mattijs Janssens
Thanks.
Cem
Please use this forum for bug reports only. Look in the documentation or on the main forum.
Old   August 4, 2009, 11:59
Mattijs Janssens
[1]
PO
I pushed a fix to 1.6.x so it now runs as before without copying the stl files.
Thanks for reporting.
Mattijs
Old   August 4, 2009, 13:57
Thanks, I will give it a try today
cheers
PO
[snappyHexMesh] SnappyHexMesh in Parallel bastil OpenFOAM Meshing & Mesh Conversion 22 April 7, 2010 11:48
Parallel case setup boundry conditions snappyhexmesh oskar OpenFOAM Pre-Processing 5 September 11, 2009 01:12
interDyMFoam fails in parallel nikos_fb16 OpenFOAM Running, Solving & CFD 2 March 28, 2009 12:07
Ignition fails in parallel run combustion solvers msha OpenFOAM Bugs 17 January 17, 2009 03:49
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 12:44
