Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
ParaView: Number of cells/points in mesh and field don't match
Like Tree1Likes
  • 1 Post By Jaggy_Snake
Old   December 5, 2012, 08:54
Default ParaView: Number of cells/points in mesh and field don't match
Fergus
Jaggy_Snake is on a distinguished road
Hi guys,
Running the incompressible motorBike tutorial with ./Allrun
I can view the mesh OK but when I click 'play' or scroll through the time bar to try to view pressure, velocity contours etc I'm getting error messages:
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481
vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 22 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/U: Expected number, string or (, found flowVelocity
vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/k: Expected number, string or (, found turbulentKE
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6882
vtkOpenFOAMReaderPrivate (0x2c71c50): boundaryField motorBike_frt-fairing:001%1 not found in object nut at time = 0
vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/omega: Expected number, string or (, found turbulentOmega
vtkOpenFOAMReaderPrivate (0x2c71c50): Error reading line 21 of /home/fergus/OpenFOAM/fergus-2.1.1/run/tutorials/incompressible/simpleFoam/motorBike/0/p: Expected number, string or (, found pressure
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6589
vtkOpenFOAMReaderPrivate (0x2c71c50): Number of cells/points in mesh and field don't match: mesh = 343673, field = 1280
Seems like it would be a fairly straightforward thing to fix, but I haven't altered any initial conditions and instead have just used Allrun.
Any tips?
[OF2.1.1 on Ubuntu 12.04 hosted on Win7]
ghazal_1989 likes this.
Jaggy_Snake is offline   Reply With Quote
Old   December 9, 2012, 09:01
Fergus
This issue seems to have resolved itself, or I am doing something differently.
However, I've now got another problem. My velocities will not plot on ParaView, see here.
Old   March 1, 2017, 09:06
Default Could you find any solution for this problem?
ghazal_1989 is on a distinguished road
Hi jaggy, I have this problem after these years, Could you find any solution for this problem?
Originally Posted by Jaggy_Snake View Post
Hi guys,
Any tips?
ghazal_1989 is offline   Reply With Quote
[snappyHexMesh] Number of cells/points in mesh and field don't match kd55 OpenFOAM Meshing & Mesh Conversion 20 March 11, 2024 06:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
